> 3.3 turbo update pics..., It's a wheelbarrow now...
Mugs914
post Nov 5 2005, 12:32 AM
"Hey, yellow IS faster!"
Well, it has front suspension now! (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif)
The spindles were re-bored to get a little more camber, dropped one inch on the tubes and gusseted. The A-arms are seam welded and reinforced in the sway bar link area.
The curreent set-up is Koni yellows, Weltmeister bushings, and 23mm torsion bars, though it will probably get coilovers before it hits the track. Eventually the stock A-arms will be replaced by 935 type ball jointed arms.
Here's a pic of the strut tube before paint.
Mugs914
post Nov 5 2005, 01:06 AM
QUOTE (J P Stein @ Nov 4 2005, 10:49 PM)
Are you going to joggle the steering arm or use the ERP tie rod extensions?
(edit) Oops, that last pic answers the question.
Actually, the steering rack has been raised quite a bit. Once I get it on the ground and determine final ride height I'll see if its enough.
If I need more I'll use the extensions...
Mugs914   3.3 turbo update pics...   Nov 5 2005, 12:32 AM
Mugs914   'Nuther...   Nov 5 2005, 12:33 AM
Mugs914   One more...   Nov 5 2005, 12:34 AM
Mugs914   Here's the whole thing in place. Got to make s...   Nov 5 2005, 12:41 AM
Mugs914   Here's another that shows the dropped spindle ...   Nov 5 2005, 12:46 AM
J P Stein   Are you going to joggle the steering arm or use th...   Nov 5 2005, 12:49 AM
Mugs914   "Where's the beef...?!!!" Looks f...   Nov 5 2005, 12:53 AM
Mugs914   Yeah dummy, where IS the beef... Helps if you act...   Nov 5 2005, 12:55 AM
Mugs914   ...   Nov 5 2005, 01:06 AM
Andyrew   I have tire envy.... I wish i knew where you guys...   Nov 5 2005, 03:33 AM
0396     Nov 5 2005, 07:04 AM
rick 918-S   Rear flare on the front... Wild   Nov 5 2005, 09:13 AM
airsix     Nov 5 2005, 10:58 AM
Mugs914     Nov 5 2005, 04:44 PM
Mugs914     Nov 5 2005, 06:21 PM
J P Stein   I get em' from America's Tire ....over yon...   Nov 5 2005, 06:28 PM
- Lo-Fi Version Time is now: 4th July 2025 - 11:36 AM
