> 3.3 turbo update pics..., It's a wheelbarrow now...
Mugs914
post Nov 5 2005, 12:32 AM
"Hey, yellow IS faster!"
Well, it has front suspension now! (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif)
The spindles were re-bored to get a little more camber, dropped one inch on the tubes and gusseted. The A-arms are seam welded and reinforced in the sway bar link area.
The curreent set-up is Koni yellows, Weltmeister bushings, and 23mm torsion bars, though it will probably get coilovers before it hits the track. Eventually the stock A-arms will be replaced by 935 type ball jointed arms.
Here's a pic of the strut tube before paint.
Mugs914
post Nov 5 2005, 04:44 PM
QUOTE (airsix @ Nov 5 2005, 08:58 AM)
QUOTE (0396 @ Nov 5 2005, 05:04 AM)
But one question, how do you "re-bored" the spindles
to get more negative?
I'm guessing the spindle was taken off the strut tube and the angle of the hole the strut-tube slides through was changed.
-Ben M.
Yup, thats it. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
My buddy Rod Lindsey made a fixture to hold the spindle on the mill so that we can dial in just about any angle we want and re-bore the hole. The hole is also "stepped" so that the spindle could slide further up the tube.
Mugs914   3.3 turbo update pics...   Nov 5 2005, 12:32 AM
Mugs914   'Nuther...   Nov 5 2005, 12:33 AM
Mugs914   One more...   Nov 5 2005, 12:34 AM
Mugs914   Here's the whole thing in place. Got to make s...   Nov 5 2005, 12:41 AM
Mugs914   Here's another that shows the dropped spindle ...   Nov 5 2005, 12:46 AM
J P Stein   Are you going to joggle the steering arm or use th...   Nov 5 2005, 12:49 AM
Mugs914   "Where's the beef...?!!!" Looks f...   Nov 5 2005, 12:53 AM
Mugs914   Yeah dummy, where IS the beef... Helps if you act...   Nov 5 2005, 12:55 AM
Mugs914   ...   Nov 5 2005, 01:06 AM
Andyrew   I have tire envy.... I wish i knew where you guys...   Nov 5 2005, 03:33 AM
0396     Nov 5 2005, 07:04 AM
rick 918-S   Rear flare on the front... Wild   Nov 5 2005, 09:13 AM
airsix     Nov 5 2005, 10:58 AM
Mugs914     Nov 5 2005, 04:44 PM
Mugs914     Nov 5 2005, 06:21 PM
J P Stein   I get em' from America's Tire ....over yon...   Nov 5 2005, 06:28 PM
- Lo-Fi Version Time is now: 4th July 2025 - 11:43 AM
