200 mph 914 |
200 mph 914 |
dwillouby |
Jan 3 2006, 07:21 PM
Member Group: Members Posts: 393 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None |
hello,
Been thinking about a new project. Has anyone driven a 914 over 200 mph? Enough horsepower can be obtained with a V8. Might need turbos to keep the motor reasonable. Aside from the required safety mods. any input on areo tricks would be helpful. I know a stock body tends to get very light at high speed. My stock bodied V8 conversion starts getting real skittish around 145. Can this be done or am I nuts? Thanks David |
lapuwali |
Jan 3 2006, 08:23 PM
Depending on how aerodynamically clean you can make a 914 so it generates no more than a reasonable amount of lift (say, under 500lbs total) at 200mph, then you'll need to make at least 500hp to overcome the aero drag to hit that speed. At those kinds of speeds, any losses (rolling resistance, driveline drag, bearing drag) start to make a big difference, so 600-700hp is more likely to get you past the 200mph mark than "only" 500. Getting that kind of power out of an SBC is certainly doable, but still pretty expensive.
Then there's the gearing problem... |
Lo-Fi Version | Time is now: 8th June 2024 - 08:43 AM |
