front wheel bearings ..., how tight is too tight ??? |
McMark |
Jan 21 2006, 05:31 PM
andy here, using mcmarks computer ...
quick question: putting back together my 911 front end and got the nut for the hub as tight as it goes, wheel still spins freely. shouldn't there be some drag ??? how tight is tight enough ??? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Andy |
lapuwali |
Jan 21 2006, 07:22 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
My technique has been to snug up the wheel nut very tight, while also using a big screwdriver against two temp. lug bolts to spin the hub as I tighten. This keeps the rollers from dimpling the races. Usually, the wheel will barely turn once fully tight like this. I then back if off completely, then tighten it down WITH MY FINGERS until I can't feel any wiggle in the wheel.
Alfa manuals (very similar front end design) have you tighten to 35 ft/lbs, then back off, then retighten to 7ft/lbs. If you can't feel any wiggle in the wheel, it's tight enough. If you can't spin the wheel freely as well, it's too tight. |
Lo-Fi Version | Time is now: 11th June 2024 - 09:35 AM |
