> Brake Bleeding Woes, How to bleed brakes with 240 calipers
Huff
post Feb 14 2006, 11:12 AM
Any help out there? I am converting my 75 2.0l to Volvo girling calipers and can't get it bled properly. I have installed a new 19mm MC, all new rotors, new rear calipers, T for the proportioning valve, new Volvo 240 calipers with T's to put the two to one line conversion, SS flex brake lines and all necessary plumbing.
I have bled and bled and bled, etc... Started RR, LR, RF, LF in that order and have tried bleeding the two Volvo upper fittings in pairs and separately. The pedal is stiff after pumping brakes repeatedly with only 2"-3" of travel. When you let off and push slowly, the pedal goes 4"-6" and is mushy. Any help?
jsteele22
post Feb 14 2006, 11:31 AM
I'd second the advice on the power bleeder. Those things are awesome. Pump up some pressure, open the bleeder valve, and the fluid come shooting out in a very impressive stream. If therer's any air, dirt, etc in the lines, it'll come out for sure.
- Lo-Fi Version Time is now: 12th July 2025 - 03:52 PM
