| neo914-6 |
Feb 26 2006, 10:47 PM
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
I know the cyl order, just not sure which plug wires orient on the dist.
Where's Levi when you need him? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Attached image(s)
| Twystd1 |
Feb 26 2006, 10:57 PM
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,515 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
Put the balancer on the engine.
Pull #1 spark plug. Stick finger in #1 spark plug hole. Have bro turn engine with long handled breaker bar, and a socket on the snout bolt. Wait till it come up to compression stroke. See if the ZERO on the balancer kinda aligns with rod on your timing chain cover. And look in the spark plug hole or stick a plastic straw in the spark plug hole till ya have a sense if the piston is at TDC on compression stroke. Then pull cap.. Wherever the rotor is pointed... that is number 1 |
neo914-6 V8 topic: How do you install a HEI distributor Feb 26 2006, 10:47 PM
neo914-6 to add complexity I have a pointer on the gear dri... Feb 26 2006, 10:49 PM
messix find tdc on #1. install dist. rotor will now be at... Feb 26 2006, 10:59 PM
messix i doubt that the pointer will be accurate on whate... Feb 26 2006, 11:03 PM
3liter914-6 Feb 26 2006, 11:05 PM
Twystd1 If ya have it dead nutz.. (I would)
Messix is corr... Feb 26 2006, 11:46 PM
neo914-6 Thanks guys,
The HEI rotor is not as "pointed" a... Feb 27 2006, 03:24 AM
Crazyhippy These guys got it covered, just be careful w/ the ... Feb 27 2006, 02:37 PM
efeinsmith If the distributor was removed, then the static ti... Feb 27 2006, 06:33 PM
Mueller ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:46 PM |
