> V8 topic: How do you install a HEI distributor, when none came with the engine...
neo914-6
post Feb 26 2006, 10:47 PM
neo life
I know the cyl order, just not sure which plug wires orient on the dist.
Where's Levi when you need him? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Twystd1
post Feb 26 2006, 11:46 PM
You don't want to know... really.....
If ya have it dead nutz.. (I would)
Messix is correct.
Come to think of it...
To time the engine with a timing light..
You are going to HAVE TO KNOW exactly where TDC is.
So the pointer is accurately reflecting the TDC or whatever degree BTC your balancer is supposed to show..
Else your gunna be stuck timing it by feel... (not) (but it can work if it's all ya got)
Thanks Messix.
By the way... Does the balancer have degree tape or markings on it?????
Twystd1
neo914-6   V8 topic: How do you install a HEI distributor   Feb 26 2006, 10:47 PM
neo914-6   to add complexity I have a pointer on the gear dri...   Feb 26 2006, 10:49 PM
Twystd1   Put the balancer on the engine. Pull #1 spark plu...   Feb 26 2006, 10:57 PM
messix   find tdc on #1. install dist. rotor will now be at...   Feb 26 2006, 10:59 PM
messix   i doubt that the pointer will be accurate on whate...   Feb 26 2006, 11:03 PM
3liter914-6     Feb 26 2006, 11:05 PM
Twystd1   If ya have it dead nutz.. (I would) Messix is corr...   Feb 26 2006, 11:46 PM
neo914-6   Thanks guys, The HEI rotor is not as "pointed" a...   Feb 27 2006, 03:24 AM
Crazyhippy   These guys got it covered, just be careful w/ the ...   Feb 27 2006, 02:37 PM
efeinsmith   If the distributor was removed, then the static ti...   Feb 27 2006, 06:33 PM
Mueller
- Lo-Fi Version Time is now: 2nd April 2026 - 11:11 AM
