| neo914-6 |
Feb 26 2006, 10:47 PM
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
I know the cyl order, just not sure which plug wires orient on the dist.
Where's Levi when you need him? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Attached image(s)
| neo914-6 |
Feb 27 2006, 03:24 AM
Thanks guys,
The HEI rotor is not as "pointed" as non-HEI... The engine ran in a car for a year. The PO just removed his injection manifold and dist... I didn't even install the original pointer since the belts were in the way. PO ran elect. water pump... Attached image(s)
neo914-6 V8 topic: How do you install a HEI distributor Feb 26 2006, 10:47 PM
neo914-6 to add complexity I have a pointer on the gear dri... Feb 26 2006, 10:49 PM
Twystd1 Put the balancer on the engine.
Pull #1 spark plu... Feb 26 2006, 10:57 PM
messix find tdc on #1. install dist. rotor will now be at... Feb 26 2006, 10:59 PM
messix i doubt that the pointer will be accurate on whate... Feb 26 2006, 11:03 PM
3liter914-6 Feb 26 2006, 11:05 PM
Twystd1 If ya have it dead nutz.. (I would)
Messix is corr... Feb 26 2006, 11:46 PM
Crazyhippy These guys got it covered, just be careful w/ the ... Feb 27 2006, 02:37 PM
efeinsmith If the distributor was removed, then the static ti... Feb 27 2006, 06:33 PM
Mueller ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:13 AM |
