> V8 topic: How do you install a HEI distributor, when none came with the engine...
neo914-6
post Feb 26 2006, 10:47 PM
neo life
I know the cyl order, just not sure which plug wires orient on the dist.
Where's Levi when you need him? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
efeinsmith
post Feb 27 2006, 06:33 PM
If the distributor was removed, then the static timing will need to be checked. As was described earlier, when cyl. 1 is at TDC on compression, the rotor should be pointing to the wire for cyl. 1, but you need to position the toothed wheel in the HEI distributor (below the rotor) so that its teeth line up exactly with the teeth of the pickup coil. That should set the engine timing at TDC. You can experiment from there.
Eric
neo914-6   V8 topic: How do you install a HEI distributor   Feb 26 2006, 10:47 PM
neo914-6   to add complexity I have a pointer on the gear dri...   Feb 26 2006, 10:49 PM
Twystd1   Put the balancer on the engine. Pull #1 spark plu...   Feb 26 2006, 10:57 PM
messix   find tdc on #1. install dist. rotor will now be at...   Feb 26 2006, 10:59 PM
messix   i doubt that the pointer will be accurate on whate...   Feb 26 2006, 11:03 PM
3liter914-6     Feb 26 2006, 11:05 PM
Twystd1   If ya have it dead nutz.. (I would) Messix is corr...   Feb 26 2006, 11:46 PM
neo914-6   Thanks guys, The HEI rotor is not as "pointed" a...   Feb 27 2006, 03:24 AM
Crazyhippy   These guys got it covered, just be careful w/ the ...   Feb 27 2006, 02:37 PM
efeinsmith   If the distributor was removed, then the static ti...   Feb 27 2006, 06:33 PM
Mueller
- Lo-Fi Version Time is now: 2nd April 2026 - 11:10 AM
