| Mueller |
Apr 4 2006, 03:19 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Slightly warmed up /4 motor applications...I'm thinking just about any design better than none at all....I'd like to metal spin these myself, however if I can get a good price on 8 from a fellow non-club member, I'll go that route (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
| Thorshammer |
Apr 7 2006, 11:06 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 754 Joined: 11-November 03 Member No.: 1,335 |
Since I worked for Suzuki for 5 years, I thought I might comment on this particular situation. Yes, the slot in the rubber velocity stack was to reduce the intake reversion on this model, The 2003 had different cams that caused some minor fuel distribution issues we worked out by doing this simple mod. It does not work in all applications. The intake port velocity on this engine is completely different than that of the 914 4/6engine. Also a GSXR1000 will regularly spin to 12,600 rpm. None of us ever will, or at least we will not have any straight valves after that. This mod would be an R&D affair. For GSXR 1000 race engines I build, we remove these stacks and install a stack that is a touch shorter, with a 12mm rounded edge which increases flow and changes the torque peak. The stack is also void of all slots unlike the standard piece. As far as 4D to determine the correct radius for the velocity stack bellmouth, this would be a good starting point, I checked some of the ones I have and they range from 3.5D to 5D. Interesting. I wish I could give you a reason why I arrrived at the sizing I did, but I don't. This is one area we have not discussed, and I have a trial set for my next dyno run. I really think aircleaners are very important, But I have glued a upside down top shaped piece of plastic to the under side of the air box pointed towards the carb velocity stack. I am hoping to guide some more air into the carb without restricting it. Stole the idea from Buell motorcycles. We'll See! Erik Madsen |
Mueller Volocity stack design considerations?? Apr 4 2006, 03:19 PM
bd1308 carbs have had velocity stacks for years.... Apr 4 2006, 03:42 PM
spunone Just send me the measurements and if we ever meet ... Apr 4 2006, 03:52 PM
spunone You can roll outer edge back onto itself I have m... Apr 4 2006, 04:04 PM
SirAndy Apr 4 2006, 04:14 PM
jsteele22 Hey Mike,
Don't know if you've run ac... Apr 4 2006, 04:27 PM
ClayPerrine Velocity of Sound Website - Maker of Velocity Stac... Apr 4 2006, 04:38 PM
ClayPerrine I still want to know why you are reinventing the w... Apr 4 2006, 04:40 PM
ClayPerrine If you are really pimpin'. you would use the... Apr 4 2006, 04:41 PM
Mueller Apr 4 2006, 05:14 PM
Thorshammer The outer lip needs to be rounded. The edge is ver... Apr 4 2006, 09:05 PM
retrotech I tested air flow with vacume cleaner suction & sm... Apr 4 2006, 09:48 PM
Twystd1 YUP... What everybody else said about the rounded ... Apr 5 2006, 12:43 AM
Porcharu Get that mill going Mike. Make an insert and pres... Apr 5 2006, 02:09 AM
jsteele22 I don't know anything about the design of velo... Apr 5 2006, 11:28 AM
maf914 Lot's of good ideas, but how come no one has m... Apr 5 2006, 01:31 PM
Mueller Apr 5 2006, 01:38 PM
Aaron Cox yummy jenevey's http://www.914w... Apr 5 2006, 01:43 PM
Aaron Cox OMG! they even make "injected air horns"!... Apr 5 2006, 01:44 PM
Mueller aaron,
here is video showing how many of the spu... Apr 5 2006, 01:50 PM
spunone Ok one more for ya fellas .On a few nitro drag bik... Apr 5 2006, 01:50 PM
jsteele22 I don't know why two stacks would give more ai... Apr 5 2006, 02:43 PM
john rogers Something to think about, are you going to run air... Apr 5 2006, 02:49 PM
Aaron Cox what if you had 4 different size stacks????
... Apr 5 2006, 03:27 PM
jsteele22 ... Apr 5 2006, 03:28 PM
Aaron Cox Apr 5 2006, 03:29 PM
jsteele22 ... Apr 5 2006, 03:42 PM
bd1308 guys, we need to think outside of the box.
I am g... Apr 5 2006, 04:02 PM
TimT ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:34 PM |
