> Engine rebuild... help wanted. Engine Rebuild 101, Clayton... this one's for you?
timmcgraw67
post May 8 2006, 05:25 PM
Clayton if you see this sorry not going the jake way.. can't return items... (IMG:style_emoticons/default/headbang.gif)
What can I say... I'm rebuilding my engine on a tight budget
I have here's how it goes as far as what I have you guys can tell me what I need, seals and bearings also.
96mm p's and c's
73 grind web cam
web cam lifters
victor reinz Engine Kit
stock block (cleaned), the rest is in boxes
Fill in the rest on what is manditory in rebuilds (Is machining really necessary?) can't I just put stock bearings,
Dr Evil
post May 8 2006, 05:29 PM
Send me your transmission!
You should have your crank and rods checked at the machine shop. If you go all of the way down to them and neglect this then you will waste all of your time, money and parts. The case should be checked as well. You can have then hot tank it for you while there at it. How are the heads? You should have a definitive answer.
- Lo-Fi Version Time is now: 2nd April 2026 - 09:24 AM
