TROJANMAN |
Looks nice in pictures......... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,275 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None ![]() |
First has never been a problem. In fact, in high school, i used to just sometimes skip to second and steal third, before taking home. (IMG:style_emoticons/default/chairfall.gif)
But this weekend, first became a problem. The story goes as such: I drove the car 5000 miles to what felt like the center of the earth in a small town called Lamar,CO. The place they show on the news every morning as the day's "hot spot" in the state. I proceeded to track the car on Satruday and Sunday. (BTW there is absolutlety no reason to EVER travel east of Denver. It all looks the same, and you can actually see the curvature of the earth.) (IMG:style_emoticons/default/biggrin.gif) First gear was fine all weekend, no problems. After my second to last run, it was gone. I say second to last, because i tracked the car one more time without first gear and without any problems. Every other gear is just fine. No problems shifting, or finding any other gear. I drove the car home without incident. (hit 118 on the speedo. and trust me NO ONE was around) We drained half the tranny oil at the track, and there was no metal to be found. I just can't find first gear. We checked the linkage, and everything seems to be moving ok, except when i am looking for first. all bushings appear to be in tact, and i am guessing if i had a problem with my firewall bushing, i would not be able to shift so smoothly to the other 4 gears (+reverse) that i am using. I did have some slight grind when finding third on the track, and maybe i was hitting first, but i sincerely doubt it. especially since my fist gear has always been tempramental. I only ever shift into first when i am at a complete stop, and i wait for it to pop in, before attempting to move forward. Plus, I didn't grind any other gears all weekend, just on the last run, and it was only, ever so slight. BTW, on the track, I only used 3,4, and 5. 1st and 2nd were only used at the starter. Thanks in Advance (IMG:style_emoticons/default/smile.gif) (brant, care to add.....?) |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
If you can shift into reverse then the shift fork is installed and it is not a shifter problem.
What sounds do you get when you try 1st? From my own experiences: -If your shift rod was binding a little on your engine mount bar then your synchro band would soon become shinny = bad. - It is possible for your brake band stop and pillow block to come out of your synchro band (rare, but possible). What you should do is take the tail cone off and check your 1st gear and related items. Things to note: -Index the shift fork rod so you can reinstal the fork inthe same position again (keeps your fork alignment nice so you dont have to pull the stack to readjust). -Remove the fork, slider, and 1st gear. -Take pics so we can see. |
TROJANMAN |
If you can shift into reverse then the shift fork is installed and it is not a shifter problem. What sounds do you get when you try 1st? From my own experiences: -If your shift rod was binding a little on your engine mount bar then your synchro band would soon become shinny = bad. - It is possible for your brake band stop and pillow block to come out of your synchro band (rare, but possible). what sounds? #$%&^@! (wait, that's the sound of me cursing) (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/biggrin.gif) I do not believe the shift rod is binding. (but where it would it be binding?) every other gear is quite smooth. and there was no chunks of anything in my gear oil. why is the your second diagnosis so rare? that sounds more possible, if everything else is clean, doesn't it? (IMG:style_emoticons/default/idea.gif) kev, no freeplay in reverse. rear cup bushing appears ok. i will check the front conncection tonight. thanks everyone. this is great (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 3rd September 2025 - 01:19 AM |
