> How much will it cost?, A price quote from Brad
r_towle
post Oct 7 2003, 07:16 PM
Custom Member
Brad,
I will deliver you a chassis all modified, ready to go with an original six engine mount, cage and rough body work complete.
I want you to find, install, tweek, road test, and finish
the following
3.6 motor /6
G50 tranny with limited slip
bigger axles and CV joints (you spec)
cable shifter
Engine management (original kit for the 3.6)
Front mount oil cooler (I will leave the size up to you, basically I will cut the front bumper and add the lower GT valance)
What else??
Body and interior I will take care of as well as the cage, though I could be convinced to let Tony do it while its there, otherwise I may stick with Chris because he is close enough for me to go down there, and I want to do a few un conventional things here.
then I will come get it.
So, no shipping for you, just find and install the basic list above.
Brad Roberts
post Oct 8 2003, 09:15 PM
914 Freak!
Since 99% of my customers will keep the small tube holes.. I need to come up with a solution that fits the factory pieces. The 1997 993 used the heat from the heat exchangers and a helper heating element in the heating fan air stream. If I dont think I can come up with something decent.. it will have to come from oil heat.
B
r_towle   How much will it cost?   Oct 7 2003, 07:16 PM
redshift   $21,980.00 Do I get a prize if I am closest?...   Oct 7 2003, 07:19 PM
r_towle   ok, for under 30k (the average price of a new car)...   Oct 7 2003, 07:21 PM
URY914   Just sign him a blank check and he'll fill in ...   Oct 7 2003, 07:27 PM
r_towle   ;) My 1.7 is destined to have the 2.0 liter instal...   Oct 7 2003, 07:32 PM
!   Geez....ain't nutin' I can't do for th...   Oct 7 2003, 07:36 PM
redshift   Oh no way! So say $22k, plus (a car you ...   Oct 7 2003, 07:42 PM
URY914   The easiest way to do it is.... Step #1. Sit in ca...   Oct 7 2003, 07:43 PM
r_towle   basically what I had in mind, I will cut and race ...   Oct 7 2003, 07:47 PM
Brad Roberts   20k is a good guess just going over your list. I ...   Oct 8 2003, 12:56 PM
r_towle   What would you recommend for the tranny and shifte...   Oct 8 2003, 07:32 PM
TimT   G50/50 6 speed with built with a short stack, and ...   Oct 8 2003, 08:10 PM
Brad Roberts   To ease install and parts availabilty.. stick with...   Oct 8 2003, 08:33 PM
r_towle   ok, how about heat? Can I still have some sort of ...   Oct 8 2003, 08:41 PM
!   Heat's fer weenies....put a jacket on and driv...   Oct 8 2003, 08:42 PM
Aaron Cox   billy boat makes 914-6 headers w/ and w/o heat, th...   Oct 8 2003, 08:43 PM
r_towle   mikez, a fitting reply for someone who sees three ...   Oct 8 2003, 08:48 PM
Brad Roberts   There is not a 9146 header on the market that fits...   Oct 8 2003, 08:52 PM
r_towle   So, where does the heat go??? through that stupid ...   Oct 8 2003, 08:58 PM
Brad Roberts   Since 99% of my customers will keep the small tube...   Oct 8 2003, 09:15 PM
Jake Raby   DAMN! LOL   Oct 8 2003, 09:18 PM
Brad Roberts   300 reliable HP factory injected and a factory gea...   Oct 8 2003, 09:24 PM
McMark   Gas heaters are supposed to rock. I don't kno...   Oct 8 2003, 10:56 PM
- Lo-Fi Version Time is now: 15th July 2025 - 09:55 AM
