anyone using a grinder to strip, less painfull than sand? |
bustruscket |
Jul 14 2006, 09:50 AM
Newbie Group: Members Posts: 6 Joined: 27-June 06 From: York Pa. Member No.: 6,315 |
I was grinding the rust out of my longs, when I got the notion to keep going. Has anyone done this with decent results? The hypothesis would be that a brass cup would generate less heat than a sanding disk. Any thoughts.
I should also state that my homebuilt air compressor is a little on the whimpy side. Quincy pump 3.8 scfm @ 100 psi. (probably not enough to run a d/a) Thoughts and criticism (on the idea) are welcome. thanks bryan. This is my second post. Please be patient. |
smdubovsky |
Jul 14 2006, 02:09 PM
Member Group: Members Posts: 331 Joined: 27-September 04 From: Silver Spring, MD Member No.: 2,837 Region Association: MidAtlantic Region |
Eastwood has a brillow pad type paint stripper (probably a 3M or notron product) that goes on a RA grinder. Supposedly works well.
SMD |
Lo-Fi Version | Time is now: 7th June 2024 - 02:27 AM |
