Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
okay, so I have a device I want to turn on for 10 to 20 seconds via the output going to a relay, off to be a few seconds.
I just downloaded pspice student version to see if I can mimic the circuit which I am not sure if the student version can do so..... using a kit from Ramsey http://www.ramseyelectronics.com/downloads/manuals/UT5.pdf other res. I have on hand are 1M (variable), a couple of 100K and a bunch of 1K....for extra caps, 100uF is the max |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,292 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
Some of the datasheets are flakey also. I forget which one, but a BIG name supplier didn't have a resistor in the discharge to ground that would limit the current to a reasonable value. You use a big cap and it would fry the chip since the current was unlimited; ie: a direct short to ground. The CMOS versions are very current limited. Don't forget the diode across the relay solenoid to kill the turn-off spike, that would cause flakey behavior if not included.
Lo-Fi Version | Time is now: 13th July 2025 - 06:46 PM |
