> What kind of starter is this on my Renegade V8?, I can I fix it?
914-8
post Nov 22 2006, 05:28 PM
Battery is fine, but when I try to start it, all I get is a solenoid click. Like maybe it's jammed? Car won't turn over. Push started the car just fine, drove around, parked it and tried to start it, but no dice. Just a click.
This is apparently a Renegage "factory" conversion, done in the mid 90s. What kind of starter is this? Some random dude once told me it is from a Mitsubishi diesel. Correct?
Also, it looks like a separate solenoid on it? Is it replaceable? Can I take it off while the starter is on the car? How do I diagnose the problem?
The starter itself seemed to be working strong, no problem, before today.
(IMG:http://img.photobucket.com/albums/v520/bak535/Picture247.jpg)
wbergtho
post Nov 24 2006, 02:21 AM
Sawzall?
914-8   What kind of starter is this on my Renegade V8?   Nov 22 2006, 05:28 PM
Brad Roberts   Diesel..LOL IMI starters right near you sells the...   Nov 22 2006, 05:33 PM
Brad Roberts   Crazy U-joint setup you got going there!! ...   Nov 22 2006, 05:34 PM
neo914-6   check your connections and ground...   Nov 22 2006, 05:44 PM
wbergtho   Brad's right...it's the IMI E-Bay mini sta...   Nov 22 2006, 05:50 PM
Dr. Roger   it looks like there is an adaptor plate. if there...   Nov 22 2006, 05:51 PM
Rand   I doubt it's the solenoid. Agree with checking...   Nov 22 2006, 05:57 PM
Brad Roberts   Roger, it is a Japanese small car starter with a ...   Nov 22 2006, 06:07 PM
914-8   Thanks guys. I'll check the grounds and conne...   Nov 22 2006, 06:26 PM
Brad Roberts   Shoot another shot for me. I'll figure them ou...   Nov 22 2006, 06:28 PM
JPB   Any drive shaft repair places can make you a set o...   Nov 22 2006, 07:00 PM
914-8   The prior owner had the car built entirely by chec...   Nov 22 2006, 07:34 PM
drive-ability   My moneys on the axles being Corvair :boing:   Nov 22 2006, 11:59 PM
sixnotfour   Corvair and Corvette axles have no linear slip joi...   Nov 23 2006, 12:33 AM
914-8   Got it fixed, thanks guys. It was a loose connect...   Nov 23 2006, 01:59 PM
wbergtho   Sawzall?   Nov 24 2006, 02:21 AM
Twystd1   Those are ford style front driveshaft pieces for a...   Nov 24 2006, 02:34 AM
914-8   Hey C, Yeah, you can see the circlips in the firs...   Nov 24 2006, 11:34 AM
bondo   You take the clips out, and beat it one way until ...   Nov 24 2006, 01:02 PM
Andyrew   Can you say heavy???? Strong though....   Nov 24 2006, 08:08 PM
Twystd1   Hey 914-8. Your lifters are DEFINETLY anti pump u...   Nov 24 2006, 08:29 PM
- Lo-Fi Version Time is now: 7th July 2025 - 08:41 AM
