Dr.914 quiz, 700 good things to know, Or to learn. |
So.Cal.914 |
Jan 31 2007, 02:34 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Continued from Cooltimes thread (Thanks Mike) How about it Doc?
r_towle |
Feb 1 2007, 04:17 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Well, depending upon how you read the question...
To stop the squeak, apply glycerin to the rubber (hard rubber) stops on the rear roof where it latches to the targa bar... If its how do I tighten the roof,,, You either shim the latch with tubing, adjust the latch, or get a new rear roof gasket. Simple is the first one. Rich |
dr914@autoatlanta.com |
Feb 1 2007, 05:08 PM
914 Guru Group: Members Posts: 7,888 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Well, depending upon how you read the question... To stop the squeak, apply glycerin to the rubber (hard rubber) stops on the rear roof where it latches to the targa bar... If its how do I tighten the roof,,, You either shim the latch with tubing, adjust the latch, or get a new rear roof gasket. Simple is the first one. Rich close enough. If one looks at the rubber snubber on the roof, you will see that the holes in it are slotted. Simply loosening the allen bolts and sliding it inward, tightens the top and allows the latches to pull the top down harder. |
Lo-Fi Version | Time is now: 4th June 2024 - 04:44 AM |
