Rear bushings, removal/replacement - How? |
Doug Leggins |
Nov 16 2003, 08:03 PM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
I am considering replacing the rear bushings while I have the trailing arms out. It is not intuitive to me how to remove the existing bushings. It doesn't look like they can be disassembled. (IMG:style_emoticons/default/confused24.gif)
Studs on both ends. nothing to put a wrench on. What am I missing? The factory manuals indicate that the rear bushings are not replaceable. I know better - I know that some of you have done this. I've searched for references on how to disassemble/ reassemble the rear trailing arm bushings but could not find enough info to figure it out. (IMG:style_emoticons/default/headbang.gif) Need some help! How are the rear bushings removed/reinstalled? Attached image(s) |
markb |
Nov 16 2003, 10:22 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
QUOTE(Jeroen @ Nov 16 2003, 06:15 PM) Go to a shop and have the threaded shafts pressed out cheers, Jeroen (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 06:08 PM |
