Doug Leggins |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None ![]() ![]() ![]() |
I am considering replacing the rear bushings while I have the trailing arms out. It is not intuitive to me how to remove the existing bushings. It doesn't look like they can be disassembled. (IMG:style_emoticons/default/confused24.gif)
Studs on both ends. nothing to put a wrench on. What am I missing? The factory manuals indicate that the rear bushings are not replaceable. I know better - I know that some of you have done this. I've searched for references on how to disassemble/ reassemble the rear trailing arm bushings but could not find enough info to figure it out. (IMG:style_emoticons/default/headbang.gif) Need some help! How are the rear bushings removed/reinstalled? Attached image(s) ![]() |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
QUOTE(J P Stein @ Nov 17 2003, 06:30 AM) Real men use fire...Candyasses take their problems to someone else Yep, you can always choose the JP-Route... (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) and (IMG:style_emoticons/default/smash.gif) some more If the part breaks, some additional (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) may be needed (IMG:style_emoticons/default/wink.gif) cheers, Jeroen |
Lo-Fi Version | Time is now: 9th July 2025 - 03:21 PM |
