> 914 webber conversion made...now what?
stephenf
post Feb 17 2007, 03:22 PM
ive taken 1.8L and put 96mm big bore on, balanced pistons
a newer cam better tuned for the carbs,
44idf webbers, targa exhaust
complete rebuild
removed all heater boxes and dammed the ports
all smog equip removed
Q: car runs pretty well, occasional pop out of the carbs
the problem is sitting at idle with the windows down....the fumes are just noxious
any suggestions:
msd?
changing stock idf jets to what?
signed
hatin to slow down and smell the flowers
stephenf
post Feb 19 2007, 10:05 PM
thank you everyone for the fast response....
this tool is great...ill have to look into the specs and get back....
i did take out the charcoal cannister and routed the hose to under the car...thats what i thought the smell was at first....
the plugs seemed to look pretty well last time i checked it....so i dont think its running so rich to ruin the motor....
so ill check the sizes and numbers.....and repost later this week
thanks again
stephenf   914 webber conversion made...now what?   Feb 17 2007, 03:22 PM
dr914@autoatlanta.com   ive taken 1.8L and put 96mm big bore on, balance...   Feb 17 2007, 03:48 PM
fat73   ive taken 1.8L and put 96mm big bore on, balanc...   Feb 20 2007, 09:03 AM
stephenf   Thanks for the input but i made a mistake on my po...   Feb 24 2007, 02:49 PM
terrymason   2. WHERE THE OIL BREATHER TUBE RUNS OUT OF THE T...   Feb 24 2007, 11:42 PM
jr91472   What have you done regarding tuning and syncing th...   Feb 17 2007, 03:49 PM
r_towle   what size venturis do you have. what size main, ai...   Feb 17 2007, 04:47 PM
john rogers   I would suggest finding someone or someplace that ...   Feb 17 2007, 11:01 PM
SirAndy   I agree that 44s are probably a tad to big. :agr...   Feb 17 2007, 11:37 PM
Borderline   I'm building a similar 1911cc engine, IRC, for...   Feb 17 2007, 11:50 PM
SirAndy   I'm building a similar 1911cc engine, IRC, fo...   Feb 18 2007, 12:10 AM
Twystd1   WITHOUT THE SPECS OF THE CARBS......... We can...   Feb 18 2007, 01:37 AM
lotus_65   did you say you removed the charcoal cannister and...   Feb 18 2007, 07:10 AM
stephenf   thank you everyone for the fast response.... this...   Feb 19 2007, 10:05 PM
John   Is the odor that you smell raw gas or exhaust?   Feb 24 2007, 07:43 PM
904svo   Check your float levels if too high it will spill ...   Feb 24 2007, 08:08 PM
Twystd1   Your Webers ARE going to pop for the first 5 minut...   Feb 24 2007, 10:47 PM
- Lo-Fi Version Time is now: 16th June 2024 - 08:06 PM
