Mazda RX 7 Oil Cooler, Ok Experts ... need an answer |
SLITS |
Feb 19 2007, 01:50 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
I have been told by a budding engineer type that using the Mazda RX7 Oil Cooler with internal thermostat will require removal of the thermostat.
My question is WHY? The thermostat bypasses the cooler until operating temp is reached, so what is the difference between the internal one and an external one? Oh, cooler will be installed on the scavenge line of a /6 as if it makes any difference. |
michel richard |
Feb 20 2007, 09:46 AM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
FWIW, I used a Mazda cooler too. Here's a thread I had on the subject. I ended up cutting a whole end off, and having a new one welded on. You do need to make sure there's a baffle in the end between the two connection fittings, to make sure the oil is forced through the radiator and does not simpluy use a shortcut inside the "end box"
http://www.914world.com/bbs2/index.php?act...t=44825&hl= Michel |
Lo-Fi Version | Time is now: 10th June 2024 - 12:10 PM |
