> Chassis Dip, What should I expect
ChicagoChris
post Mar 20 2007, 03:53 PM
It was jack-stand-tastic!
Who among us has ever dipped a Teener? My project looks in prett good shape but I am scared of what I would get (or not get) back.
jk76.914
post Mar 20 2007, 08:00 PM
(I think these pictures are too big, but I've spent enough time putting this thing together, so here we go!)
I used a hybrid approach. I had the doors, engine lid, headlight covers and blinds dipped. These were easy to get primer into the cracks and crevices, because you could rotate them every which way and slosh the primer around.
I went to Redi-Strip. They have franchises in a handful of places around the country. They advertise in Hemmings. They do the dipping in their caustic hot tub, followed by neutralizer, followed by some kind of phosphate (zinc?) dip that will buy you a few days to get it primed. They had a '64 1/2 mustang convert in the bath. It was hanging by chains, and the brew was bubbling. Reminded me of several Vincent Price movies I saw when was a kid.
The dipping AND the blasting of the trunk lids was all less than $400.
They also do blasting, anything from a small part up to a whole car. They were blasting a whole 1969 Dodge Dart when I was there. Can you believe that?
I had the two trunk lids blasted. Originally, I was going to dip them as well, but I talked myself out of it because of the areas in the channels that I doubted I could clean thoroughly or repaint thoroughly.
The rest of the upper exterior body, namely the fenders, I hand sanded. Not much sheet metal to sand when the other stuff is off.
Interior of the trunks, hellhole, etc were different. The car was Ziebarted back in '79, so all I really needed to do was soak that stuff off. What a mess, but underneath was like-new white sheet metal (original color). Some light sanding finished it up.....
All I did to the underside was clean and re-undercoat. My car had rust on one jack point, and some surface rust under the battery.
Not the case with a lot of 914s, but the point I'm making is that you don't have to do the whole car using one set approach.....
Good luck! Better you than me! Lots of work.
ChicagoChris   Chassis Dip   Mar 20 2007, 03:53 PM
McMark   I have dealt with two dipped cars up close and per...   Mar 20 2007, 04:34 PM
LarryR   I have dealt with two dipped cars up close and pe...   Mar 20 2007, 11:39 PM
Bartlett 914   Hi Chris Did you see this about Kelley's car?...   Mar 20 2007, 04:40 PM
Twystd1   There are 2 kinds of full car immersion tank strip...   Mar 20 2007, 04:47 PM
jd74914   If you don't want to dip the car I met a guy (...   Mar 20 2007, 05:03 PM
Bartlett 914   The method from the guys in the link from Kelly us...   Mar 20 2007, 05:46 PM
Phoenix-MN   I had my tub dipped by the electrolytic method als...   Mar 20 2007, 06:49 PM
rick 918-S   I had my tub dipped by the electrolytic method al...   Mar 20 2007, 07:53 PM
jk76.914   (I think these pictures are too big, but I've ...   Mar 20 2007, 08:00 PM
GeorgeRud   Are these methods better than media blasting? It ...   Mar 20 2007, 08:02 PM
dflesburg   Expect Fahrvernnugen! http://www.valhallarac...   Mar 20 2007, 08:28 PM
TimT   We had just had a 930 tub stripped by Redi-Strip i...   Mar 20 2007, 08:32 PM
John   It's by FAR the easiest way to strip a car to ...   Mar 20 2007, 08:38 PM
jk76.914   It's by FAR the easiest way to strip a car to...   Mar 20 2007, 08:43 PM
bd1308   so what now? Dipping + blasting = no rust and pai...   Mar 20 2007, 09:29 PM
John   so what now? Dipping + blasting = no rust and pa...   Mar 20 2007, 10:19 PM
9146FAN   Chris, My 6 is currently on a rotisserie. I asked...   Mar 20 2007, 10:51 PM
flesburg   The car John has pictures of was dipped at a compa...   Mar 20 2007, 11:08 PM
John   I saw the ultimate solution just last night in a t...   Mar 20 2007, 11:34 PM
Twystd1   That is just sick... Thanks...!!!...   Mar 20 2007, 11:55 PM
LarryR   Mine was not even acid dipped but every surface wa...   Mar 21 2007, 12:23 AM
LarryR   :)   Mar 21 2007, 12:29 AM
dflesburg   porsche's are not investments.... they are a...   Mar 21 2007, 08:37 AM
Phoenix-MN   Rick, I had it dipped many years ago at a place...   Mar 21 2007, 09:47 AM
flesburg   Chicago: The company I used is Redi-Strip. Locate...   Mar 27 2007, 10:24 PM
- Lo-Fi Version Time is now: 8th July 2025 - 04:01 PM
