> What is the best way to remove, Rubberized undercoating?
skline
post Mar 23 2007, 01:20 PM
Born to Drive
Ok, I decided to strip all the undercoating off from the areas I want to weld in the stiffening kits. I thought it was just some thick black paint but it is in fact undercoating. I got a chemical stripper and it says it will remove all coatings in one shot. I have applied the first coat and then scraped it but it seems a bit tougher than I thought. Any other suggestions on what I can use to remove all this stuff?
Porcharu
post Mar 23 2007, 04:06 PM
Angle grinder with a wire/cable cup wheel. Goes thru undercoating like butter. You MUST wear some big heavy gloves with this thing - if it gets loose you will bleed. A lot. Then a quick wipe with some laquer thinner and it's clean bare metal.
skline
post Mar 23 2007, 04:11 PM
Born to Drive
QUOTE(Porcharu @ Mar 23 2007, 02:06 PM) *
That sounds like you are speaking from experience? I have had my run ins with wire wheels and they can be quite damaging. Thanks for the tip though.
- Lo-Fi Version Time is now: 31st July 2025 - 11:36 PM
