| Randal |
Nov 21 2003, 05:57 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
I bought one of those infrared heat-measuring guns and thought I was really pretty cool out there measuring the temperature (inside, middle, outside) on my tires, only to discover from Tony that the infrared guns are not the way to go. It was also fun at Buttonwillow to measure the blacktop temperature (140).
Now, in order to get a more accurate temperature reading, I have to get one of those probe-measuring devices. Which unit has worked for you and where do you find them? |
Brad Roberts The key is.. infrared works. It's not as consi... Nov 21 2003, 06:01 PM
TimT Infrared is fine, like Brad says. Just be consitan... Nov 21 2003, 06:55 PM
Jeroen Ok, I'm having a related debate about tire tem... Nov 21 2003, 09:52 PM
Brad Roberts Um... yeah. Pretty easy common sense answer. Heat ... Nov 21 2003, 10:00 PM
Jeroen Yeah, that's what I thought I knew :rolleyes:... Nov 21 2003, 10:08 PM
Brad Roberts Tire chain ?? He runs a tire store ??
b Nov 21 2003, 10:10 PM
Jeroen Top-management posistion...
You won't believe ... Nov 21 2003, 10:14 PM
Brad Roberts For a tire store ?? correct ??
You made reference... Nov 21 2003, 10:27 PM
Jeroen No, he's not an engineer... just a self procla... Nov 21 2003, 10:48 PM
Brad Roberts Ha ha. So far.. the Yokohama rep for SoCal is one ... Nov 21 2003, 11:01 PM
Tony C Geez, that's funny boys, I have NEVER seen an ... Nov 25 2003, 11:13 PM
Brad Roberts I think it will work fine for Randal. It doesnt wo... Nov 26 2003, 12:27 AM
nealnorlack Hi,
I just recently attended a tech s... Nov 26 2003, 02:36 AM
J P Stein Yes. I have a problem with my tire engineer.
As s... Nov 26 2003, 03:51 AM
r_towle Jeroen,
I would simply say that the laws of physic... Nov 26 2003, 12:42 PM
Jeroen I already mentioned him that...
His response?
"Th... Nov 26 2003, 04:42 PM
r_towle Sound like he's spending to much time at the "... Nov 26 2003, 06:25 PM
Jeroen The debate went on for 5 BBS pages...
In the end ... Nov 26 2003, 06:27 PM
kwales Can you say bullshitter....er... I mean Marketing ... Nov 26 2003, 07:10 PM
Randal [Yes. I have a problem with my tire engineer]
Ac... Nov 26 2003, 07:15 PM
J P Stein ![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 09:09 PM |
