> i have to pull the engine, locked up
rhodyguy
post May 7 2007, 03:05 PM
the engine would turn (by hand) prior to the install. initially it turned fine when trying to start it. never did light off. made a wierd noise or 2, now, it won't turn at all. full charge on bat. starter just clicks. plugs out, in gear, pass side tire chocked, i can not turn the engine with the dr side tire at all. like it's hitting something. i have 0 answers or ideas. just about at the end and ready to take a huge loss on everything. debating whether to pull the engine, and just roll the car out and tarp it. words can not express....
k
Jake Raby
post May 7 2007, 03:39 PM
Engine Surgeon
sounds like something is jammed in the flywheel/ clutch area...
ALWAYS make it a point to turn the engine after mating it to the gearbox!!! BEFORE install!
rhodyguy   i have to pull the engine   May 7 2007, 03:05 PM
Justinp71   You could have dropped a valve seat, that happened...   May 7 2007, 03:12 PM
bd1308   yeah i have had a valve pop off and get lodged in ...   May 7 2007, 03:17 PM
rhodyguy   i have not started this engine. there was no metal...   May 7 2007, 03:23 PM
SLITS   Will the engine turn backwards from the point of l...   May 7 2007, 03:26 PM
rhodyguy   ill go check.   May 7 2007, 03:31 PM
rhodyguy   no i can't. tried to turn it with the dr side ...   May 7 2007, 03:37 PM
Jake Raby   sounds like something is jammed in the flywheel/ c...   May 7 2007, 03:39 PM
rhodyguy   puttin' on the coveralls and getting started. ...   May 7 2007, 03:43 PM
Joe Ricard   Just drop the transaxle off and see if you can tur...   May 7 2007, 03:44 PM
SLITS   I'd do a quick check on the starter to see if ...   May 7 2007, 03:48 PM
So.Cal.914   I'd do a quick check on the starter to see if...   May 7 2007, 04:07 PM
rhodyguy   by check, you mean just remove the starter first? ...   May 7 2007, 03:50 PM
Twystd1   yes   May 7 2007, 04:06 PM
rhodyguy   starter out. no sign of hammering on the starter g...   May 7 2007, 04:18 PM
rhodyguy   btw. the engine does rotate with the starter remov...   May 7 2007, 04:45 PM
So.Cal.914   btw. the engine does rotate with the starter remo...   May 7 2007, 09:35 PM
rhodyguy   HA! <_< while rotating the engine i note...   May 7 2007, 05:04 PM
SLITS   Now, the fact that it does rotate is REALLY GOOD N...   May 7 2007, 05:12 PM
rhodyguy   there is a tight .018" distance from the outs...   May 7 2007, 05:30 PM
John   You are going to have to at least pull the trans o...   May 7 2007, 05:43 PM
rhodyguy   th whole package is coming out john.   May 7 2007, 06:05 PM
rhodyguy   is the fw being this close to the bell housing on ...   May 7 2007, 07:49 PM
davep   I can't see anything bad there.   May 7 2007, 07:59 PM
So.Cal.914   Looks right to me also. Did you test the starter?   May 7 2007, 08:18 PM
Aaron Cox   check this one out..... did you put a NEW oil pum...   May 7 2007, 08:20 PM
rhodyguy   <_< 215 vs 210? disc that came out is identi...   May 7 2007, 08:49 PM
Demick   Please tell me you didn't use this pressure pl...   May 7 2007, 08:58 PM
SLITS   Kevin ..... I thought maybe you changed the flywhe...   May 7 2007, 09:04 PM
So.Cal.914   Nope, I think your right Ron. Looks bad to me also...   May 7 2007, 09:28 PM
John   So does the engine turn freely with the trans off?   May 7 2007, 09:31 PM
rhodyguy   that fw is not the on that came with the engine. i...   May 7 2007, 10:08 PM
John   what about a pic of the starter?   May 7 2007, 10:18 PM
rhodyguy   i put this starter in during the wcc04' in the...   May 7 2007, 11:42 PM
John   Have you found any shiny spots where it was rubbin...   May 8 2007, 12:00 AM
rhodyguy   i'm being a bit unclear. so i'll back trac...   May 8 2007, 12:08 AM
So.Cal.914   I know that I sound like a broken record but have ...   May 8 2007, 12:17 AM
Twystd1   Starter gear is skipping against the top of the FW...   May 8 2007, 01:08 AM
rhodyguy   i don't know anyone with a loose, known good s...   May 8 2007, 09:23 AM
Root_Werks   i don't know anyone with a loose, known good ...   May 8 2007, 10:17 AM
So.Cal.914   i don't know anyone with a loose, known good ...   May 8 2007, 10:30 AM
davep   I don't like the look of the flywheel to crank...   May 8 2007, 09:52 AM
rhodyguy   new pivot bushing, clip, t.o. bearing were install...   May 8 2007, 10:16 AM
rhodyguy   i'll push the 914 to marysville and we'll ...   May 8 2007, 10:29 AM
echocanyons   :agree: Test the starter while out of the car....   May 8 2007, 11:02 AM
rhodyguy   i took this before the old engine pull. i'll ...   May 8 2007, 11:13 AM
Bartlett 914   i took this before the old engine pull. i'll...   May 8 2007, 11:23 AM
rhodyguy   got off the phone w/dan root. he's going to ma...   May 8 2007, 11:24 AM
Root_Werks   got off the phone w/dan root. he's going to m...   May 9 2007, 05:39 PM
Ferg   Cool! I hope you figure this out. Don't ...   May 8 2007, 11:33 AM
rhodyguy   i've heard dave hunt's h.t. starter in act...   May 8 2007, 11:41 AM
vsg914   use the jumper cable method to test everything wit...   May 8 2007, 11:54 AM
Travis Neff   I just did a bench test on mine, hook the positive...   May 8 2007, 12:33 PM
Twystd1   The problem probably isn't the starter section...   May 8 2007, 01:28 PM
Gint   As long as nothing smashes your face in Kevin, I f...   May 8 2007, 03:42 PM
Aaron Cox   your local FLAPS will test the starter for you.......   May 8 2007, 05:16 PM
Twystd1   The Flaps idea is a good one. There is one proble...   May 8 2007, 05:54 PM
LS6/914   Crap, Ive been on the train too long again. K, I h...   May 9 2007, 05:55 PM
Root_Werks   Kevin, let me know if you got the starter yet. In...   May 13 2007, 02:47 PM
sixnotfour   Dan he is over here; http://www.914world.com/bbs2/...   May 13 2007, 04:08 PM
Root_Werks   Dan he is over here; http://www.914world.com/bbs2...   May 13 2007, 04:51 PM
- Lo-Fi Version Time is now: 6th July 2025 - 10:35 AM
