> Learned something new, tire temperatures
Randal
post Nov 21 2003, 05:57 PM
I bought one of those infrared heat-measuring guns and thought I was really pretty cool out there measuring the temperature (inside, middle, outside) on my tires, only to discover from Tony that the infrared guns are not the way to go. It was also fun at Buttonwillow to measure the blacktop temperature (140).
Now, in order to get a more accurate temperature reading, I have to get one of those probe-measuring devices. Which unit has worked for you and where do you find them?
Jeroen
post Nov 26 2003, 04:42 PM
Region Association: Europe
I already mentioned him that...
His response?
"The contact patch will cool down faster because the heat will sink into the road/track surface... The non-contact patch will hold the radiant heat"
(IMG:style_emoticons/default/blink.gif)
He ain't a racist (AFAIK) but he sure sounds like Alfred (IMG:style_emoticons/default/biggrin.gif)
cheers,
Jeroen
Randal   Learned something new   Nov 21 2003, 05:57 PM
Brad Roberts   The key is.. infrared works. It's not as consi...   Nov 21 2003, 06:01 PM
TimT   Infrared is fine, like Brad says. Just be consitan...   Nov 21 2003, 06:55 PM
Jeroen   Ok, I'm having a related debate about tire tem...   Nov 21 2003, 09:52 PM
Brad Roberts   Um... yeah. Pretty easy common sense answer. Heat ...   Nov 21 2003, 10:00 PM
Jeroen   Yeah, that's what I thought I knew :rolleyes:...   Nov 21 2003, 10:08 PM
Brad Roberts   Tire chain ?? He runs a tire store ?? b   Nov 21 2003, 10:10 PM
Jeroen   Top-management posistion... You won't believe ...   Nov 21 2003, 10:14 PM
Brad Roberts   For a tire store ?? correct ?? You made reference...   Nov 21 2003, 10:27 PM
Jeroen   No, he's not an engineer... just a self procla...   Nov 21 2003, 10:48 PM
Brad Roberts   Ha ha. So far.. the Yokohama rep for SoCal is one ...   Nov 21 2003, 11:01 PM
Tony C   Geez, that's funny boys, I have NEVER seen an ...   Nov 25 2003, 11:13 PM
Brad Roberts   I think it will work fine for Randal. It doesnt wo...   Nov 26 2003, 12:27 AM
nealnorlack   Hi, I just recently attended a tech s...   Nov 26 2003, 02:36 AM
J P Stein   Yes. I have a problem with my tire engineer. As s...   Nov 26 2003, 03:51 AM
r_towle   Jeroen, I would simply say that the laws of physic...   Nov 26 2003, 12:42 PM
Jeroen   I already mentioned him that... His response? "Th...   Nov 26 2003, 04:42 PM
r_towle   Sound like he's spending to much time at the "...   Nov 26 2003, 06:25 PM
Jeroen   The debate went on for 5 BBS pages... In the end ...   Nov 26 2003, 06:27 PM
kwales   Can you say bullshitter....er... I mean Marketing ...   Nov 26 2003, 07:10 PM
Randal   [Yes. I have a problem with my tire engineer] Ac...   Nov 26 2003, 07:15 PM
J P Stein     Nov 27 2003, 02:32 AM
- Lo-Fi Version Time is now: 16th April 2026 - 09:09 PM
