| Dr Evil |
May 27 2007, 01:33 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
I remember no too long ago someone posted a bitchen link to a mini V8 made from 2 hyabusa engines. It was a great idea, but out of the price and consideration range for probably all of us. This got me to thinking, though. The hard part is having to cast a block and a crank to fit the hyabusas together. While this engine is by far the bset choice for car applilcations due to its overwhelming power, there has to be another, easier alternative.
I was wondering how hard it would be to take 2 honda V4 1100 engines (pretty common and easy to get) and make the out put of one to the shaft of another. This would remove any need for a contiguous case/crank and yet serve the same purpose. The hondas came to mind because it is what I am familiar with in teh V4 configuration. They would be compact, easy to plumb, high rev, relatively low maitenance, and high in cool factor. Or, how about mating two large V engines together = more tq, lower reving, air cooled (or not). With the ponies that the motorcycle engines are pushing these days, adding 2 togather would give a light car like ours a nice boost and probably be lost of fun. Any thoughts? If I had it my way I would mate two BMW K1100 16V engines together in a flat opposed 8 configuration, but thats a bit out of my skills level. |
| Dr Evil |
May 27 2007, 03:33 PM
Hey man, dreaming in free!
Actually, with 2x 1100 V4 engines you could get 200hp and a 8-10K red line in a compact package. All I am thinking is a crdle to hold the two bolted together, and run the radiators in cool looking ducts in the side behind the doors. The engines are not much $$ at all. Who will do it? Maybe me some day, but by then I will likely be forced to mate two hydrogen cell engines together... |
| woobn8r |
May 27 2007, 05:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 607 Joined: 7-January 07 From: Newmarket, Ontario, Canada Member No.: 7,435 Region Association: None |
Hey man, dreaming in free! Actually, with 2x 1100 V4 engines you could get 200hp and a 8-10K red line in a compact package. All I am thinking is a crdle to hold the two bolted together, and run the radiators in cool looking ducts in the side behind the doors. The engines are not much $$ at all. Who will do it? Maybe me some day, but by then I will likely be forced to mate two hydrogen cell engines together... You can get in excess 0f 230HP our of a normally aspirated rotary engine and it'll rev forever.... Add another rotor (3) and put yourself in the 350 hp range... Then you can turbo it...or add yet another rotor or both... ....if small lightweight, high HP, high revving engines is what you're after.... I've even seen the thread on putting a rotary in a 911..... |
| Dr Evil |
May 27 2007, 05:58 PM
Hey man, dreaming in free! Actually, with 2x 1100 V4 engines you could get 200hp and a 8-10K red line in a compact package. All I am thinking is a crdle to hold the two bolted together, and run the radiators in cool looking ducts in the side behind the doors. The engines are not much $$ at all. Who will do it? Maybe me some day, but by then I will likely be forced to mate two hydrogen cell engines together... You can get in excess 0f 230HP our of a normally aspirated rotary engine and it'll rev forever.... Add another rotor (3) and put yourself in the 350 hp range... Then you can turbo it...or add yet another rotor or both... ....if small lightweight, high HP, high revving engines is what you're after.... I've even seen the thread on putting a rotary in a 911..... That is not exactly my whole point. A rotary would also cook you pretty good and be rather uninventive (been done to death). I like the motorcycle idea, not that I am going to do it before I am 50 as I will be paying back loans....(IMG:style_emoticons/default/dry.gif) |
Dr Evil Mini V8? Could it be done, easily? May 27 2007, 01:33 PM
alpha434 Didn't we have a thread on this? Where we bash... May 27 2007, 02:01 PM
Vacca Rabite
Any thoughts?
Aside from the cool "Look w... May 27 2007, 03:14 PM
SirAndy just weld two type 4 cranks together and make a ni... May 27 2007, 03:30 PM
McMark Did the 'factory' flat 8 914s have the tru... May 27 2007, 03:33 PM
Did the 'factory' flat 8 914s have the tr... May 27 2007, 03:34 PM
Dr Evil Good question of the factory 8s, I have no idea ho... May 27 2007, 03:34 PM
Good question of the factory 8s, I have no idea h... May 27 2007, 03:39 PM
Dr Evil I was just considering your welding of 2 1.7s toge... May 27 2007, 03:41 PM
I was just considering your welding of 2 1.7s tog... May 27 2007, 03:50 PM
Dr Evil "look at the factory drawing of 914111 in DGV... May 27 2007, 03:45 PM
914-8
"look at the factory drawing of 914111 in DG... May 27 2007, 03:50 PM
"look at the factory drawing of 914111 in DG... May 27 2007, 03:51 PM
Dr Evil Danke!
Ya, while Im in there <_<
Two... May 27 2007, 04:04 PM
alpha434 you guys are funny. You wouldn't double the ho... May 27 2007, 05:15 PM
messix
you guys are funny. You wouldn't double the h... May 27 2007, 06:03 PM
alpha434
you guys are funny. You wouldn't double the ... May 27 2007, 06:09 PM
Thomas J Bliznik Hi Guys,
You can put a chevy into anything if you... May 27 2007, 05:41 PM
Dr Evil I was thinking something along the lines of an 83 ... May 27 2007, 06:14 PM
Dr Evil Yup, now coveting the V-max engine. 1200cc, 145hp,... May 27 2007, 06:22 PM
grantsfo Why not just save the weight and go for a single 1... May 27 2007, 06:30 PM
grantsfo here is a site that shows some cool conversion wor... May 27 2007, 06:42 PM
Dr Evil Yup, that was the kind of stuff that spurned the i... May 27 2007, 07:07 PM
Twystd1 Stuff.......... May 27 2007, 08:31 PM
PinetreePorsche Seems a lot easier just to do the Subie thing--a 4... May 27 2007, 09:09 PM
Dr Evil Clayton, thanks man. You said it, and enough said ... May 27 2007, 09:37 PM
rick 918-S I love this crazy stuff. :headbanger:
I'm ... May 28 2007, 12:03 AM
Paul Illick
I'm ... May 28 2007, 06:27 AM
messix i think putting some thing like 10 chain saw engin... May 28 2007, 12:15 AM
grantsfo How about two Harleys? May 28 2007, 12:16 AM
messix that could be timed to sound soooooo wicked!... May 28 2007, 12:28 AM
grantsfo I like this site. Good potos of engine build, dia... May 28 2007, 12:33 AM
GS Guy
I like this site. Good potos of engine build, di... May 28 2007, 06:47 AM
Dr Evil Now yer talkin! Thats cool.
I was figuring th... May 28 2007, 12:52 AM
spare time toys Check zcars.org they have kits to stick a suzuki e... May 28 2007, 06:01 AM
i love porsche heres a mini V8, 548 CC displacement, using Ninja ... May 28 2007, 09:54 AM
Paul Illick OMG, that's absolutely incredible. Did YOU do... May 28 2007, 10:21 AM
kwales Here ya go...
Matra Simca Bagheera engine......
... May 28 2007, 12:02 PM
Dr Evil Man, some cool stuff coming out of the wood work. ... May 28 2007, 12:34 PM
DEC here pics from the
"Red Porsche Killer... May 28 2007, 12:49 PM
roadster fan Here is a link to the info on the mini v8 from WWU... May 28 2007, 01:46 PM
grantsfo Found this on text about possibilities of grafting... May 28 2007, 02:23 PM
BKLA Check out the DP1 website - He is using a Hartley ... May 28 2007, 10:46 PM
Brando Why not get an older ferrari V12? I think they cam... May 29 2007, 12:49 PM
Johny Blackstain
Why not get an older ferrari V12? I think they ca... May 29 2007, 01:39 PM
Mike D.
Why not get an older ferrari V12? I think they ca... May 29 2007, 01:42 PM
dwillouby Why dont you just cut a chevy V8 in half? Makes a ... May 29 2007, 01:18 PM
RoninEclipse2G
Why dont you just cut a chevy V8 in half? Makes a... May 29 2007, 01:24 PM
ClayPerrine How about a 12 cylinder that is shorter than a 911... May 29 2007, 01:37 PM
Brando
How about a 12 cylinder that is shorter than a 91... May 29 2007, 03:14 PM
RoninEclipse2G
How about a 12 cylinder that is shorter than a 9... May 29 2007, 04:04 PM
ClayPerrine
[quote name='Brando' post='905968' date='May 29 2... May 29 2007, 04:27 PM
RoninEclipse2G
[quote name='Brando' post='905968' date='May 29 ... May 29 2007, 04:50 PM
Dr. Roger edit...
a real blown mini v8.
http://www.youtube.... May 29 2007, 06:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:04 PM |
