Straange Noise coming from engine, Sounds like a parakeet! |
Borderline |
Jun 9 2007, 11:42 PM
Senior Member Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
OK, here's the story. I dropped the engine to install the seal between the sheet metal and the oil cooler. I had the fan, and all the sheet metal off and then put everything back with the addition of the rubber seal for the oil cooler. Now its back in the car and running gud! At idle and low RPM it makes a tweeting sound that goes away at about 2.5-3K. Its not the alternator belt. I removed the belt and it still makes the same noise!
It sounds like rubber or plastic rubbing on something and I have no idea what it is. All I know is that the WCR is one week away and I don't have the time or energy to drop it again even if I knew what it was which, I don't. Any suggestions?? (IMG:style_emoticons/default/headbang.gif) |
Twystd1 |
Jun 10 2007, 01:20 AM
You don't want to know... really..... Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
Loose spark plug? Air squealing by the loose plug?
Loose carb will do that sometimes. Could be an exhaust leak at the head. Possibly Slits or Aaron sabotaged your engine? Clayton |
Lo-Fi Version | Time is now: 10th June 2024 - 11:55 AM |
