Straange Noise coming from engine, Sounds like a parakeet! |
Borderline |
Jun 9 2007, 11:42 PM
Senior Member Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
OK, here's the story. I dropped the engine to install the seal between the sheet metal and the oil cooler. I had the fan, and all the sheet metal off and then put everything back with the addition of the rubber seal for the oil cooler. Now its back in the car and running gud! At idle and low RPM it makes a tweeting sound that goes away at about 2.5-3K. Its not the alternator belt. I removed the belt and it still makes the same noise!
It sounds like rubber or plastic rubbing on something and I have no idea what it is. All I know is that the WCR is one week away and I don't have the time or energy to drop it again even if I knew what it was which, I don't. Any suggestions?? (IMG:style_emoticons/default/headbang.gif) |
Matt Romanowski |
Jun 10 2007, 10:28 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
Some pretty good ideas here. I would first check for an intake leak (squirt some carb cleaner around the intake gaskets and see if the idel changes). If it's not that, I think Mark is right, it's probably something with the fan. Take the little cover off the top and see if there is any aluminum flakes from it rubbing. Good luck.
Borderline |
Jun 10 2007, 11:14 PM
Some pretty good ideas here. I would first check for an intake leak (squirt some carb cleaner around the intake gaskets and see if the idel changes). When will I learn??? I am such an idiot! (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/chair.gif) I would have sworn it was a mechanical sound like something rubbing. The last thing I did tonight was to spray some carb cleaner around the #4 intake.....chirping stopped immediately!!!! Thanks Matt and all the rest of yall for all the ideas! Looks like WCR here I come!!! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 10:27 AM |
