Straange Noise coming from engine, Sounds like a parakeet! |
Borderline |
Jun 9 2007, 11:42 PM
Senior Member Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
OK, here's the story. I dropped the engine to install the seal between the sheet metal and the oil cooler. I had the fan, and all the sheet metal off and then put everything back with the addition of the rubber seal for the oil cooler. Now its back in the car and running gud! At idle and low RPM it makes a tweeting sound that goes away at about 2.5-3K. Its not the alternator belt. I removed the belt and it still makes the same noise!
It sounds like rubber or plastic rubbing on something and I have no idea what it is. All I know is that the WCR is one week away and I don't have the time or energy to drop it again even if I knew what it was which, I don't. Any suggestions?? (IMG:style_emoticons/default/headbang.gif) |
firstknight13 |
Jun 10 2007, 12:14 AM
Senior Member Group: Members Posts: 652 Joined: 25-March 05 From: manchester,ct. Member No.: 3,817 |
(IMG:style_emoticons/default/biggrin.gif) if you have carbs!!?? it is the linkage between the carbs...tighten the intake nuts and adjust the hex bar... if fi then ???????? (IMG:style_emoticons/default/confused24.gif)
ChrisFoley |
Jun 11 2007, 06:43 AM
I am Tangerine Racing Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
(IMG:style_emoticons/default/biggrin.gif) if you have carbs!!?? it is the linkage between the carbs...tighten the intake nuts and adjust the hex bar... if fi then ???????? (IMG:style_emoticons/default/confused24.gif) In the case of your car Ray, the squeek went away when I repaired the intake leak at the manifold base. It wasn't "mechanical" at all. |
Lo-Fi Version | Time is now: 10th June 2024 - 02:05 PM |
