> Engine smokes and idle climbs after 30 secs, 73 2.0L D-jet
highways
post Jun 17 2007, 04:25 PM
Ok.... the goal is to get this thing off the jackstands today. Yes today!
When I start the car... it sounds good and looks good except that the idle is slightly higher then it used to be (now it's 1,500- used to be 900). After about 30 secs it starts to warm up, more and more blue smoke at tailpipe and idle climbs to 2400.
Condition of the car- engine sat for 4 years. I sprayed some WD40 and a small shot glass of marvel mystery oil into the spark plug holes a few months ago before starting for the first time. Engine has run for a total of about 5 minutes since then so I don't think the extra lubrication is what's making the smoke.
Timing- distributor is in the same position as it always was.
Vacuum lines- I think I have them hooked back up correctly to the best of my knowledge.
Engine tin- there is a crack under the coil. Could this affect vacuum severly enough to cause the problem?
Heat exchanger flapper boxes are only partially hooked up. Plumbing for heat is not complete. But the heat exchangers are in place with the proper copper washers. NOTE; forgot the copper washer on one side (was letting alot of air blow out from where exchanger meets engine)... replaced them last night and the idle dropped from 2000 to the current 1500, no more air blowing out. So that definitely had something to do with it.
Any ideas on what to do next?
highways
post Jun 17 2007, 05:45 PM
Most things are rebuilt except the engine- which was running very well in December 2000. It still sounds like it's running great... smooth with no hunting or missing.
The fuel system has been redone- new fuel lines throughout, gas tank cleaned, new filters, fresh gas.
Oil has been changed. Valves adjusted. Throttle cable rests in the fully closed position.
The engine does not smoke when you start it. It looks completely normal. As it warms up the smoke gets progressively worse, and the idle climbs to 2400rpm.
- Lo-Fi Version Time is now: 4th July 2025 - 03:00 PM
