> Replacing the Throttle cable...What should I do?, Any Tips would be appreciated
purple
post Aug 2 2007, 07:41 AM
Pigeon feeders attract me
hey Guys,
My boss, the guy who got me into the porsche lifestyle, said that I should replace the throttle cable on my car, as the linkage is A: mickey mouse and B: very sticky.
The throttle sticks a LOT at low levels and like the first 10 % is not available to me.
I'll attach a picture to show what I'm working with.
My question is...how should I change the cable? do i pull from the engine bay, or from the pedal cluster? Do you guys have any tips for this process?
Thanks
Purple
purple
post Aug 2 2007, 07:56 AM
great minds think alike, eh slits?
SLITS
post Aug 2 2007, 08:05 AM
"This Utah shit is HARSH!"
QUOTE(purple @ Aug 2 2007, 06:56 AM) *
Yup.
The pedal end is a ball socket .... just snap it off the ball with a screwdriver or ?. You need to remove the ball socket and lock nut prior to pulling it out of the car from the rear.
Disconnect barrel locknut at throttle body (7 or 8 mm). Disconnect 10 mm locknuts (sandwich) that secure sheath to bracket. Push sheath/cable back down thru hole in pass side sheet metal. Pull (assuming it is disconnected at pedal end).
purple   Replacing the Throttle cable...What should I do?   Aug 2 2007, 07:41 AM
jasons   Its pretty easy really. You feed it back at the f...   Aug 2 2007, 07:47 AM
MoveQik   I just replaced mine. I unhooked it from the peda...   Aug 2 2007, 07:50 AM
purple   is it possible to wrap some string around it befor...   Aug 2 2007, 07:53 AM
SLITS   You can also tie a length of string / cord to the ...   Aug 2 2007, 07:55 AM
purple   great minds think alike, eh slits?   Aug 2 2007, 07:56 AM
SLITS   great minds think alike, eh slits? Yup. The pe...   Aug 2 2007, 08:05 AM
purple   Just curious... My pedal box (clutch specifically...   Aug 2 2007, 09:53 AM
SLITS   Bronze is nice and solves a lot of problems. Punc...   Aug 2 2007, 10:12 AM
Rob Ways   If your throttle cable is really sticky ie stuck, ...   Aug 2 2007, 10:18 AM
purple   I really was going to get one of the rebuilt ones....   Aug 2 2007, 10:22 AM
michel richard   The problem with tying a string to the cable is th...   Aug 2 2007, 10:58 AM
purple   I actually can stomp the hell out of the throttle ...   Aug 2 2007, 11:07 AM
purple   Pic as promised, sorry for the crappy lighting, i...   Aug 2 2007, 11:09 AM
Cap'n Krusty   19mm master cylinders DON'T solve spongy brake...   Aug 2 2007, 11:12 AM
purple   Would this be the correct master cylinder? Is it p...   Aug 2 2007, 11:19 AM
SLITS   Krusty may be crusty but he is correct. ATE stamp...   Aug 2 2007, 11:20 AM
purple   Would the 'terry cables' be the best for t...   Aug 2 2007, 11:23 AM
Trevorg7   I replaced both my throttle and clutch cables with...   Aug 2 2007, 12:54 PM
purple   Anybody besides me think that linkage is an abomin...   Aug 2 2007, 05:20 PM
- Lo-Fi Version Time is now: 28th September 2026 - 04:39 PM
