> Electronic Ignition, WHAT TO USE
BarberDave
post Dec 3 2003, 05:58 PM
Barberdave
o.k., I have a newly rebuilt dizzy for my F,I, conversion. the only trouble is it still has points. I have Petroix (sp) in the one i have on my 914 with a carb now. QUES. is which electronic ignition to buy ?What is your experience?
Dave (IMG:style_emoticons/default/smilie_flagge6.gif)
ArtechnikA
post Dec 4 2003, 02:24 PM
rich herzog
QUOTE(Brad Roberts @ Dec 4 2003, 11:56 AM)
I have used the Crane pieces with success also. My issue: if something goes wrong with a MSD.. I can buy them off the shelf at just about ANY FLAPS. I always have to order the Crane.
Ahh who cares.. we will have multi coil multi spark setup soon with programmable injection which will do away with all this crap.
this is one advantage of being over here on this coast - fast cheap shipping from Summit!
OTOH - like a lot of warranty / insurance issues - the only unit i've -had- to replace is the MSD, twice. the VW (Fairchild) units never failed, and Darryl Vittone has sparked some incredible HP from very radical engines with them. the Jacobs looked interesting but it looked like you need to go with "the whole system" from them and i didn't think i wanted to do that (even though that's exactly what i wound up doing with the Crane stuff - except for the Magencor plug wires ...). the Hi-6 hasn't failed (yet) and i really like the diagnostic/trigger LED, the programmable retard controller, and the switch-selectable rev-limit setting. (and if you -had- to, you could connect a MSD-6 where the HI-6 is, in but a few minutes. power, ground, trigger, tach out, cylinder-select, ta da...)
the NASCAR guys seem to love the MSD units, but even they use 2 per car (failure rate issues?) and i don't think they're using MSD-6AL's like you can get at the FLAPS.
i'm glad (reliability, ability to tie down the dizzy cap) to stay with the Crane for the moment, but i'd be glad to go to a more flexible programmable setup if i'm able to dedicate a car to track use. even though what i've got feels like it's working fine, i think there are advance-curve issues, and i'm not equipped to be playing with weights and springs.
BarberDave   Electronic Ignition   Dec 3 2003, 05:58 PM
!   Give the Petronix the float test...... I always u...   Dec 3 2003, 06:33 PM
Brad Roberts   All my Pertronix cars run just fine. The Allison/C...   Dec 3 2003, 06:37 PM
ChrisReale   My pertronix has worked great also...   Dec 3 2003, 06:38 PM
Brad Roberts   It works EVERY day in my wifes car (watch it will ...   Dec 3 2003, 06:43 PM
ChrisReale   Brad, when you move my car around, does it sould l...   Dec 3 2003, 06:49 PM
Kerrys914   Pertronix in my car and so far so good :) I do hav...   Dec 3 2003, 06:55 PM
robby750   I have run the Pertronix for almost 4 years withou...   Dec 3 2003, 06:58 PM
Brad Roberts   Mike hasnt owned a 4cyl 914 (that he drove on a re...   Dec 3 2003, 07:00 PM
philinjax   Jacobs Electronic Ignition or better yet, their ot...   Dec 3 2003, 07:01 PM
Brad Roberts   Hey Phil, Do they have a points replacement or is...   Dec 3 2003, 07:03 PM
TimT   I had the allison on a 911 I owned for about 10 yr...   Dec 3 2003, 07:10 PM
Aaron Cox   year and a half on my pertronix and counting.........   Dec 3 2003, 07:10 PM
serge914   I have a Mallory Unilite distributor and CDI with ...   Dec 3 2003, 07:29 PM
URY914   I'm running the Crane opitcal points, CD and c...   Dec 3 2003, 07:44 PM
Air_Cooled_Nut   Had Compufire electronic points in one car, Pertro...   Dec 3 2003, 08:37 PM
Doug Leggins   The pertronix is the best 60 bucks that I have spe...   Dec 3 2003, 08:44 PM
Aaron Cox   what does the msd 6al do?   Dec 3 2003, 08:54 PM
Brad Roberts   The MSD6al gives you soft touch rev control and gi...   Dec 4 2003, 02:11 AM
ArtechnikA   Crane HI-6 and optical points replacement all the ...   Dec 4 2003, 07:25 AM
KenH   Will the TACH work with the CRANE or do you need s...   Dec 4 2003, 11:30 AM
ArtechnikA
  Dec 4 2003, 11:46 AM
philinjax   Brad, Jacobs do not supply electronic points, ju...   Dec 4 2003, 12:10 PM
Brad Roberts   I have used the Crane pieces with success also. My...   Dec 4 2003, 01:56 PM
ArtechnikA   ...   Dec 5 2003, 06:45 PM
Rouser   Pertronix Ignitor, with Flame-Thrower coil and [ur...   Dec 5 2003, 09:48 PM
Jake Raby   Mallory........ Its adjustable and the best on the...   Dec 5 2003, 09:50 PM
Brad Roberts   Have you figured out a way to put the trigger poin...   Dec 5 2003, 11:45 PM
thesey914
- Lo-Fi Version Time is now: 1st July 2025 - 08:06 AM
