Front Swaybar 'Bearings', Who made/makes them? |
Brando |
Aug 6 2007, 08:27 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Looking to get a pair for my front swaybar. I've found a few complete sealed bearings available through bicycle shops, but I thought a member here made them or had them made...
Basically to use a complete sealed bearing I'd have to make a triangle-shaped housing for them to be in, then bolt that to the body in the swaybar location. It's that, or take a pair of swaybar bushing brackets, drill and braze zerg fittings into them and slot/groove/drill some bushings... Looking for the cheaper alternative of course. Bearings would be almost zero friction but zero impact absorption. Poly-graphite bushings would be medium friction and medium impact absorption. I've been looking for a way to maybe take a bearing and make a 1 to 2mm thick 'sleeve' that would ride inside a larger ID bearing, over the bar. Maybe work to absorb some impact and have minimal friction - similar to Elephant Racing's poly-bronze bushings... |
Mueller |
Aug 7 2007, 01:02 AM
I'm pretty sure the bearing that are used on the Smart Racing bars are nyliner bearings...good stuff
I had a bar (manufacture unknown) that was similar to the one you describe but the bearings were able to pivot a few degrees as well which would ensure no binding if the axis of the bearings were not aligned perfectly//// |
Lo-Fi Version | Time is now: 9th June 2024 - 03:27 AM |
