degreeoff |
I like big butts and I can not lie! ![]() ![]() ![]() Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region ![]() |
IT all really started when I bought her in 98...here she was
![]() It all started when.....after many (5 or so) years of using and trying to improve my 4 cylinder performance I blew a heli coiled plug at an autoX....well that was the end I had already sunk a shit load of $$$$ into my ride and another shit load of time and I was DONE!! time for a sixer!! see the below web site for things I did previously to my lil friend by the time I blew the plug it was a 2056 with a KH header and MSD ign. http://www.daybydayco.com/car4web/914.html OK the scoop (AKA what I have bought so far) -Engines [u](3) A 2.4 ltr 2.4 with a 7r case and CIS. A basket case 2.4 with rebuilt and ported heads, 2.2S P&C's and S+ cams +all new "stuff" to assemble it. Lastly a rebuil 2.7 with all the good machine work done newly rebuilt heads, Ross 9.8 P&C's and GE 40 cams. For induction I have weber 40IDS carbs For exhaust I have European racing headers and muffler For Ignition I have a HPV Crank fire setup For Fuel I have a Carter rotory pump and a 15 gallon cell all lines will be AN/SS braided. Suspension is out of a SC with Bilstein shocks, 22mm front sway stock rear sway, mono balls up front. 21mm TBars and 180lb springs The body panels are ALL FG hood, trunk,skirts,valances,bumpers and flares. The oil system is stock 914-6 tank and Earls front mount cooler with GT shroud MISC stuff in no particular order.....solid mounts, Momo wheel, quick release hub, WM short shifter, Momo seats, GT door pulls, Pilot fogs, NEW Porsche exterior mirrors and a shit load I am forgetting. Here is what she started as....... ![]() |
degreeoff |
The color is POR 137
Thanks I dig it! |
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
The color is POR 137 Thanks I dig it! This is a great build. I really like all the detailed pictures. I'm starting a subie conversion and have printed many of your pictures for reference of body details and your ideas. I am trying to decide how to stiffen the body for street use. I am going to build a front motor mount similiar to your's for the subie. The only suggestion I would give is to run the ground to the motor or tranny first then to the body or also to the body. I would not count on a forever good ground through the body to the motor. I imagine you are going to use the ground strap from the tranny to the body. This means you have two areas that have to remain good. Also use dielectric gease on all the connections. A few years down to road and you will be happy you did. You have gone to great detail on your build, I love it. What brand and type of paint did you use? I read where it was self etching primer so I guess it was two part epoxy primer and probably non sanding so that will probably be forever. Is the top coat single stage urethane? I wish the 914 group could get a fleet discount from ppg or some other company. We could cut paint cost in half. For a short time I could get a discount on ppg and it was about 40% less on the price. I'm anxious to see the completion. Thanks again for the pictures I probably would have paid cash for them. Charlie |
Lo-Fi Version | Time is now: 17th June 2024 - 06:41 AM |
