The eurorace header just showed up, YES! |
purple |
Oct 3 2007, 10:12 PM
Pigeon feeders attract me Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None |
Hey guys, this is something of a continuation thread of these last two threads.
http://www.914world.com/bbs2/index.php?showtopic=76498 http://www.914world.com/bbs2/index.php?showtopic=76175 The eurorace header showed up today! YES!!! Here is a pic of it sitting in the garage somewhat assembled. Now I have a couple questions: 1: Do I use only new copper gaskets? 2: Is there a specific procedure to preparing the gaskets prior to install? 3: Should I use those copper nuts or just double nut the stub pipes to the exhaust ports? 4: Should I do a little dance after putting it all on without any pulled studs? I'll post a pic of the dual motorcycle exhaust once I launch my other computer. If Jake signs in....how much will this help my engine over that dual motorcycle exhaust? Attached thumbnail(s) |
Chris Pincetich |
Oct 5 2007, 10:43 AM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
Oh yeah - tha cables.
I bought the cable heat shield and no worries so far. Clutch cable came off and slipped inside OK, speedo cable I tore open the sleeve and stapled it back together. Worked great. The 2 cables are now bundled and tied up away from the header against the engine mount, engine tin mount tab on case, and clutch pulley bracket hole. I also used fiber insulating heat wrap onthe header and collector so both the header and cables are wrapped. Heat kills! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 07:08 AM |
