carbed engine in major components, new question at the bottom. D-day, fast approaching! |
VaccaRabite |
Oct 7 2007, 10:29 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
My engine is seperated into its major components. (Motor (2056 T4), Mallory Unilite, blue coil, carbs, linkage, low pressure fuel pump, engine tin, alternator). The engine is built. But the mallory is off it, the tin is off, the carbs are off, etc.
I want to put it together, and test run it on Oct 20th before I install it into the car. I know that I am going to need a battery and wire to run the starter, fuel pump, and plugs. I know I need new gaskets when I attach the carbs to the motor. Obviously, I am going to need gas, and new oil. What else do I need? Help me make a checklist. My goal is to put the major components together, pack it in my subaru, and fire it off at the Sterling meet later this month (then put the now-together motor back in my subaru, take it home, and get it in the 914). This is a high quality wire plan for my test harness. Do I need to add anything more? Zach |
VaccaRabite |
Oct 7 2007, 10:34 AM
Checklist so far (bolded stuff I still need to get, non bolded I have allready):
Carb to motor seals Basic wire harness (battery to coil, battery to pump, switched battery to starter, anything else?) Battery (got it, but need to charge it) Feed fuel line, Low pressure fuel filter Gas (got it) Oil (got it) Engine tin screws Test run stand (ScottyB to the rescue here, I hope) Help me fill it in - what else do I need? Zach |
Lo-Fi Version | Time is now: 1st June 2024 - 01:22 AM |
