KaptKaos |
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest ![]() |
So I have the HEs installed and the muffler too.
I went top side to install the intake manifolds. I got the driver side in, but when I went to do the passenger side, I got this: ![]() That silvery stuff on the intake stud is aluminum. I didn't over torque it, it never got tight at all. So the question is, am I fuched or can I relatively easily fix this? TIA |
Twystd1 |
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,515 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 ![]() |
Locktite red won't work in his application. There aren't any threads left to stick too.
He MIGHT be able to get by with Locktite thread maker. Which is bassiclay a high temp epoxy you put in the bad hole. Then you coat the bolt/stud with mold release and stick it in the hole. After it sets. you remove the bolt/stud and voila... Insta thread cert. Problem is.. me no think it works at 400 degrees F. Me thinks the epoxy might start to degrade. I KNOW there is mil spec stuff that works. I just don't have any connects at NASA anymore. Those guys have glues and epoxys that we can only dream of. I would yank the head and do it right. Unless I had a time constraint. Then I would at least try it in the car. It's keeping the angle and not wobbling a hand drill is the hard part. Worse comes to worse. and he screws the pooch. He yanks the head. I'd have John do a Heliarc number to it. Drill it out in the mill. Install new time cert.... DONE. I dunno.. Sean. let me know if'n ya need my little drill. Clayton |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
Lo-Fi Version | Time is now: 12th July 2025 - 11:18 AM |
