The eurorace header just showed up, YES! |
purple |
Oct 3 2007, 10:12 PM
Pigeon feeders attract me Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None |
Hey guys, this is something of a continuation thread of these last two threads.
http://www.914world.com/bbs2/index.php?showtopic=76498 http://www.914world.com/bbs2/index.php?showtopic=76175 The eurorace header showed up today! YES!!! Here is a pic of it sitting in the garage somewhat assembled. Now I have a couple questions: 1: Do I use only new copper gaskets? 2: Is there a specific procedure to preparing the gaskets prior to install? 3: Should I use those copper nuts or just double nut the stub pipes to the exhaust ports? 4: Should I do a little dance after putting it all on without any pulled studs? I'll post a pic of the dual motorcycle exhaust once I launch my other computer. If Jake signs in....how much will this help my engine over that dual motorcycle exhaust? Attached thumbnail(s) |
Type 4 Unleashed |
Oct 16 2007, 01:35 AM
CREATIVE TYPE lV ENGINEERING Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
I used Earl's Flame Guard, I forget if it was 1" or 1 1/4", I ran both the Speedo & clutch thru it, the Speedo, I used a length of bailing wire thru the shield, then pulled the speedo cable end right thru.
Also, seen done by some one else, But they I believe put a slot, I just drilled a hole about 1" down & 1/4" to the left of the original hole of the clutch pulley bracket, which angels the clutch cable over the header. Also, as long as the Flame guard doesn't toch the Header it will not burn Two last things, 2 hangers, one bolted to the tranny side cover above the clutch fork, and the other an L bracket sheetmetal screwed to the side of the case where heater box tin usta screw to the case, they keep the shield and cables from header.. Link & Pic http://www.anplumbing.com/shop/index.php?s...lame!_Guard (IMG:http://i71.photobucket.com/albums/i134/Type4Unleashed/2772%20%20105%2003%20mm%20x%2080%20mm/2007_0608Image003.jpg) |
Lo-Fi Version | Time is now: 7th June 2024 - 07:46 AM |
