> Measuring fuel pressure, Help me troubleshoot my Carbs....
thomasotten
post Nov 3 2007, 09:25 AM
Dual Dellorto carb setup, the carbs tend to snap under load. After tinkering for a while with airflow and linkage and not resolving, I am going to go to basics and check fuel pressure. How do I measure this? Is there an inline guage I can buy?
thomasotten
post Nov 3 2007, 04:11 PM
Ok, I just finished adjusting the valves. Nothing was seriously out of adjustment.
Next, I went to Sears, and bought a cheap made-in-china fuel pressure guage. I'll be returning it, it's crap, but.... I am reading 3 to 3.25 psi before the carb Tee, in the engine bay. The guage is not that fine to read more precisely. It's a very new CB pump, by the way.
So I measure my flow again, it looks the same. I drive it, same crap, snaps under acceleration (right carb), even bogs a bit. Then, at idle, i thought I heard a snap...reved it up a little more by hand...let it idle again....snap (right carb)!.
So it's snaping occacionally even at no load at idle.
thomasotten   Measuring fuel pressure   Nov 3 2007, 09:25 AM
rhodyguy   confirm valve adj and timing first thomas. what pr...   Nov 3 2007, 10:20 AM
thomasotten   confirm valve adj and timing first thomas. what p...   Nov 3 2007, 10:49 AM
Bartlett 914   Dual Dellorto carb setup, the carbs tend to snap ...   Nov 3 2007, 10:23 AM
lotus_65   you have a return setup still, right? you HAVE to ...   Nov 3 2007, 12:55 PM
McMark   :agree: and you've got a quality pump, so get ...   Nov 3 2007, 12:56 PM
lotus_65   oh yea, and a gauge. mine's pretty lame compar...   Nov 3 2007, 01:09 PM
rhodyguy   the cb pump he's running does not have a retur...   Nov 3 2007, 01:32 PM
thomasotten   Ok, I just finished adjusting the valves. Nothing...   Nov 3 2007, 04:11 PM
Twystd1   Your lean going into the transition. About where ...   Nov 3 2007, 04:37 PM
thomasotten   Your lean going into the transition. About where...   Nov 3 2007, 06:46 PM
Aaron Cox   only if you want them to squirt the same amount :)...   Nov 3 2007, 06:55 PM
thomasotten   I'm on it... but, is there a general rule as t...   Nov 3 2007, 07:07 PM
McMark   You can get a small vial that can be lowered down ...   Nov 3 2007, 07:18 PM
Twystd1   Try about 1/3rd from top of threads. If no worky....   Nov 3 2007, 07:41 PM
thomasotten   Try about 1/3rd from top of threads. If no worky...   Nov 4 2007, 03:03 PM
ConeDodger   Thomas, My Dells had a pretty good vacuum leak at ...   Nov 4 2007, 03:35 PM
thomasotten   I actually watched the accelerator squirt into eac...   Nov 4 2007, 07:22 PM
McMark   Get ready to catch some fuel when you undo those f...   Nov 4 2007, 11:02 PM
type11969   All sorts of funky crap collects in those acc pump...   Nov 5 2007, 08:37 AM
thomasotten   Well, I took the carbs off, and made sure the acce...   Nov 9 2007, 04:19 PM
type11969   Did you clean out the acc pump circuits? Did you v...   Nov 9 2007, 04:32 PM
Thack   Sounds like you are too lean. Are "idle...   Nov 9 2007, 05:16 PM
- Lo-Fi Version Time is now: 16th April 2026 - 02:41 AM
