> Measuring fuel pressure, Help me troubleshoot my Carbs....
thomasotten
post Nov 3 2007, 09:25 AM
Dual Dellorto carb setup, the carbs tend to snap under load. After tinkering for a while with airflow and linkage and not resolving, I am going to go to basics and check fuel pressure. How do I measure this? Is there an inline guage I can buy?
thomasotten
post Nov 4 2007, 03:03 PM
QUOTE(Twystd1 @ Nov 3 2007, 05:41 PM) *
Try about 1/3rd from top of threads.
If no worky......
Then 1/2 from top of threads... Somewhere in there is TYPICALLY what works.
C
Well, I tried both of those settings, and several in between. I drove it at each setting and I still seem to get that snap under load. I am starting to get really frustrated, so I am coming to the board for help. Help!
Questions:
1. Is it the more you thread the nut down the threaded shaft, the more squirt your accelerator pump will provide, or the other way around?
2. What does it mean when, under load, you hear a sound from the carbs that kinda sounds like gargling?
thomasotten   Measuring fuel pressure   Nov 3 2007, 09:25 AM
rhodyguy   confirm valve adj and timing first thomas. what pr...   Nov 3 2007, 10:20 AM
thomasotten   confirm valve adj and timing first thomas. what p...   Nov 3 2007, 10:49 AM
Bartlett 914   Dual Dellorto carb setup, the carbs tend to snap ...   Nov 3 2007, 10:23 AM
lotus_65   you have a return setup still, right? you HAVE to ...   Nov 3 2007, 12:55 PM
McMark   :agree: and you've got a quality pump, so get ...   Nov 3 2007, 12:56 PM
lotus_65   oh yea, and a gauge. mine's pretty lame compar...   Nov 3 2007, 01:09 PM
rhodyguy   the cb pump he's running does not have a retur...   Nov 3 2007, 01:32 PM
thomasotten   Ok, I just finished adjusting the valves. Nothing...   Nov 3 2007, 04:11 PM
Twystd1   Your lean going into the transition. About where ...   Nov 3 2007, 04:37 PM
thomasotten   Your lean going into the transition. About where...   Nov 3 2007, 06:46 PM
Aaron Cox   only if you want them to squirt the same amount :)...   Nov 3 2007, 06:55 PM
thomasotten   I'm on it... but, is there a general rule as t...   Nov 3 2007, 07:07 PM
McMark   You can get a small vial that can be lowered down ...   Nov 3 2007, 07:18 PM
Twystd1   Try about 1/3rd from top of threads. If no worky....   Nov 3 2007, 07:41 PM
thomasotten   Try about 1/3rd from top of threads. If no worky...   Nov 4 2007, 03:03 PM
ConeDodger   Thomas, My Dells had a pretty good vacuum leak at ...   Nov 4 2007, 03:35 PM
thomasotten   I actually watched the accelerator squirt into eac...   Nov 4 2007, 07:22 PM
McMark   Get ready to catch some fuel when you undo those f...   Nov 4 2007, 11:02 PM
type11969   All sorts of funky crap collects in those acc pump...   Nov 5 2007, 08:37 AM
thomasotten   Well, I took the carbs off, and made sure the acce...   Nov 9 2007, 04:19 PM
type11969   Did you clean out the acc pump circuits? Did you v...   Nov 9 2007, 04:32 PM
Thack   Sounds like you are too lean. Are "idle...   Nov 9 2007, 05:16 PM
- Lo-Fi Version Time is now: 16th April 2026 - 02:41 AM
