| thomasotten |
Nov 3 2007, 09:25 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,572 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
Dual Dellorto carb setup, the carbs tend to snap under load. After tinkering for a while with airflow and linkage and not resolving, I am going to go to basics and check fuel pressure. How do I measure this? Is there an inline guage I can buy?
| McMark |
Nov 4 2007, 11:02 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Get ready to catch some fuel when you undo those four. Perhaps a small tear/leak in the acc pump diaphragm...
thomasotten Measuring fuel pressure Nov 3 2007, 09:25 AM
rhodyguy confirm valve adj and timing first thomas. what pr... Nov 3 2007, 10:20 AM
thomasotten
confirm valve adj and timing first thomas. what p... Nov 3 2007, 10:49 AM
Bartlett 914
Dual Dellorto carb setup, the carbs tend to snap ... Nov 3 2007, 10:23 AM
lotus_65 you have a return setup still, right?
you HAVE to ... Nov 3 2007, 12:55 PM
McMark :agree: and you've got a quality pump, so get ... Nov 3 2007, 12:56 PM
lotus_65 oh yea, and a gauge. mine's pretty lame compar... Nov 3 2007, 01:09 PM
rhodyguy the cb pump he's running does not have a retur... Nov 3 2007, 01:32 PM
thomasotten Ok, I just finished adjusting the valves. Nothing... Nov 3 2007, 04:11 PM
Twystd1 Your lean going into the transition.
About where ... Nov 3 2007, 04:37 PM
thomasotten
About where... Nov 3 2007, 06:46 PM
Aaron Cox only if you want them to squirt the same amount :)... Nov 3 2007, 06:55 PM
thomasotten I'm on it... but, is there a general rule as t... Nov 3 2007, 07:07 PM
McMark You can get a small vial that can be lowered down ... Nov 3 2007, 07:18 PM
Twystd1 Try about 1/3rd from top of threads.
If no worky.... Nov 3 2007, 07:41 PM
thomasotten
If no worky... Nov 4 2007, 03:03 PM
ConeDodger Thomas,
My Dells had a pretty good vacuum leak at ... Nov 4 2007, 03:35 PM
thomasotten I actually watched the accelerator squirt into eac... Nov 4 2007, 07:22 PM
type11969 All sorts of funky crap collects in those acc pump... Nov 5 2007, 08:37 AM
thomasotten Well, I took the carbs off, and made sure the acce... Nov 9 2007, 04:19 PM
type11969 Did you clean out the acc pump circuits?
Did you v... Nov 9 2007, 04:32 PM
Thack Sounds like you are too lean. Are "idle... Nov 9 2007, 05:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 04:30 AM |
