Major Oil Leak Part 2, Ugh, fix one another shows |
Brando |
Nov 10 2007, 08:49 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
As you guys may recall back a few months ago I put in new pushrod tube seals to cure my car's typhoid exxon-valdez. Well, it's had another outbreak and it doesn't seem to be any easier to do this time than last time.
So, i figure what I'll do is get the really soft rubber oil cooler seals, a new seal that goes between the sheet metal and oil cooler on top, the mallory unilite I've been pining over, a new oil pressure sender and the extension needed when running a unilite, new heater control cable and my prepped-and-painted passenger side heater flapper box (thanks claytonnovich!). Once everything's ready I'll announce a work party date then drive down to skline's with a small furniture dolly and some of my tools. Shortly thereafter I (and hopefully with the assistance of some fellow wrenchers) will pull the engine and transmission. Then we can go to town on the engine... Pull the impeller and housing, passenger side engine tin, oil cooler, distributor, pressure sender, oil filter. Once the passenger side of the engine is naked it'll get a vigorous spray down and scrubbing with engine cleaner, then a final rinse and prep for reassembly. Once i get the parts I'll announce the date. I'm pretty close to getting the unilite (money wise) so we'll see hopefully in the next two or three weeks. It just never ends! (IMG:style_emoticons/default/sheeplove.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/beer3.gif) |
computers4kids |
Nov 11 2007, 12:25 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
As you guys may recall back a few months ago I put in new pushrod tube seals to cure my car's typhoid exxon-valdez. Well, it's had another outbreak and it doesn't seem to be any easier to do this time than last time. It just never ends! (IMG:style_emoticons/default/sheeplove.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/beer3.gif) Just curious...is this the 75 1.8 in your signature? Have you done any mods to help the motor breathe better? puke box? vent both heads? (75's only one head is vented), crankcase/valve covers? Forget everything I just said if your 1.8 still has the stock L-Jet. Breathers=Vaccumm Leak |
Brando |
Nov 11 2007, 04:16 PM
Just curious...is this the 75 1.8 in your signature? Have you done any mods to help the motor breathe better? puke box? vent both heads? (75's only one head is vented), crankcase/valve covers? Forget everything I just said if your 1.8 still has the stock L-Jet. Breathers=Vaccumm Leak Mark, I am running a stockish 1.8 with L-Jet. I removed the piping that goes from the oil filler neck to the intake (no more crankcase ventilation to the intake) and ran a puke tube out of the engine bay. From the factory neither one of my heads are vented, just the case through the filler neck. Don't make me come over and fix your shit... Giterdone and have fun... And move to OC ya nut case........ Hows the job search going...????????????????? Claytonobitch Hey mang, I'd be honored to have you Any volunteers to help me repair the damage? Note: Further inspection in the daylight shows an incredible amount of oil around the pressure sender. I'm thinking that may be the majority cause for the leak - but i'd very much like to replace those 30+ year old oil cooler seals while i'm at it. Maybe a new front crank seal too. |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:30 PM |
