| Beamer13 |
Nov 20 2007, 12:45 AM
Member ![]() ![]() Group: Members Posts: 303 Joined: 8-November 07 From: Midwest Member No.: 8,308 Region Association: Upper MidWest |
Ok, so I'm considering (since I have to drop the engine anyway) going to a big bore kit (96mm) What exactly should I know, or what will I need to do??? I am new to Porsche and 914. If there is another thread somewhere on this, by all means please direct me to the right thread. Thanks, in advance, for everyone's help on this forum!! You've been great!!!
| Beamer13 |
Nov 20 2007, 08:15 AM
So basically what you are saying is that I can just use it with my stock L-Jet and it just bolts on, so there shouldn't be much of anything else that I would need to do? Right??
| type47 |
Nov 20 2007, 08:59 AM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
So basically what you are saying is that I can just use it with my stock L-Jet and it just bolts on, so there shouldn't be much of anything else that I would need to do? Right?? right. 1.8 bore is 93mm and big bore kit is 96mm. if there is not too much increase, the stock FI system can be maintained. i think i remember that D-jet can still be used for big bore but when the increase is alot (98-105mm), they don't work correctly. there are alot of if's, ands and buts to this but that's not the answer here to your question (L-jet on a 96mm motor). does that make the motor a 1911cc? i will admit on this board that i did not split the case on my 1.8 when i got it running. a previous poster referenced splitting the case and the majority here would probably recommend to split the case when getting the engine running. it's not that much more work and you then know the condition of the bottom end. that said, i wanted to get my 1.8 on the road to drive it and the bottom end only had 60k miles and the next motor to go into the car would be a 2L or a 2.056L anyway, so i had the cylinders honed and the pistons cleaned and put it together with new rings and installed the motor. flame on, Cap'n Attached image(s)
Beamer13 Questions on Big Bore Kits on a 1.8 Nov 20 2007, 12:45 AM
Beamer13 :bump: Nov 20 2007, 01:27 AM
Twystd1 Do you want to keep your stock fuel injection?
Or... Nov 20 2007, 02:04 AM
johannes Stroke will give you torque ... Go 2056
BTW there... Nov 20 2007, 02:42 AM
lotus_65 raby's sites Nov 20 2007, 05:24 AM
type47 big bore kits (96mm pistons and cylinders) for 2.0... Nov 20 2007, 07:04 AM
Joe Ricard All of it is bolt in once you spit the case. Nov 20 2007, 08:08 AM
Beamer13 Very cool!! Thanks much! Nov 20 2007, 09:13 AM
Cap'n Krusty Upping the bore from 93 to 96mm will raise your co... Nov 20 2007, 09:38 AM
type47
Upping the bore from 93 to 96mm will raise your c... Nov 20 2007, 11:50 AM
Beamer13 Thanks!! Good info! I can tell that ... Nov 20 2007, 09:40 AM
blitZ Increasing displacement is a plus. However, getti... Nov 20 2007, 09:43 AM
Beamer13 Ok, a friend of mine just brought me back down to ... Nov 20 2007, 09:58 AM
Beamer13 Big bore that is :-) Hopefully will have engine o... Nov 20 2007, 11:46 AM
Twystd1 Jim,
The answer is pretty simple.
When the diame... Nov 21 2007, 01:22 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:08 PM |
