DIY 3-piece wheel change-easy as it looks?, Need advice on sealing goop in the middle |
Chris Pincetich |
Nov 30 2007, 05:13 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
I've got some new to me but used 3-peice Keizer rims that are pretty awesome, and as a bonus I have 2 extra outer rim halves that can bump the width out a bit.
I'm a CSOB DIY 914 owner, and want to get out my torque wrench and power driver this weekend to take apart 2 rims and add the new halves. Is this OK to do or am I liable to fuch up the wheels in the process? Next ? - what should I use as the goop in the middle? Looks like clear silicone in there now. I've got my rear fenders out enough with the baseball bat roll for the 7" width with 205 Hooisers (AX). With the new halves I'll be at 7.5" and am crossing my fingers another few passes with the roller and heat gun will make it work in those rear fenders. Bonus photo (IMG:style_emoticons/default/beerchug.gif) |
grantsfo |
Nov 30 2007, 06:28 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
RTV Silicone Sealant
Dow Corning 832 Multi Surface Adhesive Sealant is reccommended by some manufacturers. Call Wade at Kiezer sure he can walk you though the process and reccomend the lastest stuff. Nice guy. Wade Husiman 712-737-3053 This post has been edited by grantsfo: Nov 30 2007, 06:29 PM |
stownsen914 |
Nov 30 2007, 10:02 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Call Wade at Kiezer sure he can walk you though the process and reccomend the lastest stuff. Nice guy. Wade Husiman 712-737-3053 And while you have him on the phone, make sure to ask about the torque spec on the bolts that hold the rim halves together. Also, whether the hardware needs to be replaced with every disassembly -- some wheel manufacturers recommend that. I have seen a wheel fail at a track event due to improper assembly, and it wasn't pretty. Don't be deterred though -- just follow the instructions. |
Lo-Fi Version | Time is now: 6th June 2024 - 04:48 AM |
