Does timing affect engine temps?, I swear my engine is running hotter... |
pete914 |
Jan 31 2008, 06:33 AM
Member Group: Members Posts: 178 Joined: 21-August 07 From: east coast Member No.: 8,025 |
So,
I'm running a 1.8L stock Vacuum advance dizzy with single weber (i know...not ideal) and as I've learned the advance curve is wrong for this setup and I have pretty bad lag now before 3000rpm. I swear the engine is running hotter now. Is it because the timing is too retarded in the lower rpm range? does that affect engine temperature? Anyone running a similiar setup with a suggestion as to where to set my timing to get better performance? I don't rev it up much past 4500 Oh, and I just ordered a a centrifugal advance dizzy, if someone is using one of those with a single carb and is having luck, please tell me your settings. Thanks. |
Jake Raby |
Jan 31 2008, 08:05 AM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
QUOTE Does timing affect engine temps?, I swear my engine is running hotter... ABSOLUTELY!!!!! Timing is EVERYTHING to head and oil temps! TWO degrees can make 50+ degrees of head temp! Retarded timing = higher exhaust gas temps because the burn is slowed and is still occuring while the exhaust valve is open.. High EGT= higher head temps because the port soaks all that head up and spreads it over the heat... Better get this squared away or you'll be a statistic! This post has been edited by Jake Raby: Jan 31 2008, 08:09 AM |
Lo-Fi Version | Time is now: 1st June 2024 - 09:35 PM |
