> '7X 2.7-6 Projekt Thread, Updated 5/4/08 - IT IS ALIVE... well, sort of...
KaptKaos
post Dec 17 2007, 12:05 AM
Family
I finally got my car moved around in the back so that I can get it up onto jack stands and take a look around.
My short term goal is to get the oil changed, swap the gas tank, charge the battery and try and fire her up. I took a few steps towards that today.
First, I was under there cleaning stuff up. I noticed this on the passenger side of the trans.
I assume that it is the throttle cable, but being this is my first /6, I need to confirm.
Secondly, I drained the oil from the case and the tank. For those that don't recall, here is my 911 tank, cut into the floor.
Problem is that when I drained the case and the tank, I only got 1/2 gallon of oil. I was expecting about 3.5 gallons (14 qts +/-). Not even close. This is my first dry sump motor, so am I missing something?
Here is a picture of the engine mount bar.
I don't know if this is stock, custom, aftermarket or ??? A little help pls. The mount bar sits so low that the side shift trans rod is above it.
Lastly, when I got the car, the PO said that he had buggered up the trans. Its a side shifter. I cleaned it up a little and took off the shift rod head and the ball socket. It's a new socket bushing which is nice.
I was able to move the selector through all gears. I noticed that the shift rod head was about an inch longer than the one on my car. In fact, it looked as if it was extended somehow. It's odd. I noticed this because I had to put the bushing on the ball and snap it down, before inserting it into the shift rod head. If I didn't do that, the shift rod head was so deep that I couldn't push it on. I am hoping that I get lucky with this.
Also, the cone set screw was replaced with a longer set screw, with a square head, that is drilled so it can be wired for additional safety.
Anyway, more to come soon. I have my work cut out for me.
KaptKaos
post Feb 16 2008, 06:40 PM
Family
I put a new fuel filter on it today, and I "think" the fuel system is now solid.
I attempted to start the motor. I got the "whistle" as the CIS primed. It coughed a few times but did not start (IMG:style_emoticons/default/sad.gif)
I stopped because I saw fuel coming out of the exhaust, so I hope I haven't buggered it up too badly. I am worried that this is a really bad sign.
Anyway, I am sort of out of ideas at this point. Anyone have any suggestions?
KaptKaos   '7X 2.7-6 Projekt Thread   Dec 17 2007, 12:05 AM
rick 918-S   Yes, that's your throttle linkage. I think you...   Dec 17 2007, 08:51 AM
KaptKaos   So does anyone have any clue as to why I only got ...   Dec 18 2007, 11:54 AM
sixnotfour   From the looks of the motor it has leaked a couple...   Dec 18 2007, 03:40 PM
KaptKaos   Do I check the level with the motor running? How ...   Dec 18 2007, 05:48 PM
Jeffs9146   Yes, put in about 9qts, start and check, Yes and...   Dec 18 2007, 06:02 PM
KaptKaos   Thanks Jeff :trophy: Oh, and what weight oel shou...   Dec 18 2007, 06:35 PM
Jeffs9146   That is a personal preferance. I am sure you will ...   Dec 18 2007, 06:48 PM
KaptKaos   I picked up a clean gas tank from Bruce out in Riv...   Dec 23 2007, 08:06 PM
Grimstead   1) There are two bolts that bolt the steering ra...   Dec 27 2007, 11:01 AM
KaptKaos   Oh, one other thing. The gas sender is enclosed i...   Dec 23 2007, 08:08 PM
Headrage   3/8th and 5/16 on the hose. The sender is a seale...   Dec 23 2007, 08:27 PM
Markeydoo   Kapt I have a 2.0l six with the quick six engine b...   Dec 23 2007, 08:48 PM
KaptKaos   Thanks Allan & Mark. I'll be stopping a...   Dec 23 2007, 09:27 PM
Twystd1   Do you have a oil line that runs from the trunk mo...   Dec 23 2007, 09:48 PM
KaptKaos   I drained from the bottom of the case and the bott...   Dec 24 2007, 12:14 AM
swood   Where is this "Flaps" of which you speak...   Dec 24 2007, 02:31 AM
KaptKaos   Where is this "Flaps" of which you spea...   Dec 24 2007, 08:31 AM
swood   Just givin you xmas sheet. Hope you have enough t...   Dec 24 2007, 02:41 PM
Twystd1   Crack (Loosen) all your oil lines that go from the...   Dec 27 2007, 01:24 AM
SLITS   1.) Line one goes from the bottom of the tank to ...   Dec 27 2007, 07:58 AM
dfwteenerpr   for what it's worth, a mechanic advised my bro...   Dec 27 2007, 10:02 AM
KaptKaos   Update It's not seized!!! :tr...   Dec 29 2007, 08:19 PM
euro911   Who the Fuch is this Mark character you mention, a...   Dec 30 2007, 01:25 AM
KaptKaos   Who the Fuch is this Mark character you mention, ...   Dec 30 2007, 10:11 AM
KaptKaos   So I went out there again today to try and start h...   Dec 30 2007, 05:29 PM
euro911   Have at it ... Pick your poison ... doing a litt...   Dec 30 2007, 06:32 PM
Aaron Cox   Get off your ass and get it running ! LOL ...   Jan 4 2008, 08:04 PM
Brando   How's the teener running Aaron?   Jan 4 2008, 08:10 PM
KaptKaos   :rotfl: :rotfl: Yeah, and this rain is gonna he...   Jan 4 2008, 08:27 PM
Headrage   How's the teener running Aaron? No one will...   Jan 4 2008, 08:39 PM
Aaron Cox   I drove it today......(around the block) I need t...   Jan 4 2008, 09:08 PM
Gint   This thing running yet? :driving:   Jan 5 2008, 09:03 AM
KaptKaos   Depending on the weather, I plan to pull the fuel ...   Jan 5 2008, 10:35 AM
KaptKaos   A little progress so far today. 1) It's not t...   Jan 31 2008, 02:19 PM
KaptKaos   Ok, so I got the fuel pump back in, and it's s...   Jan 31 2008, 05:06 PM
swood   Was it another holiday today...? :confused: :ch...   Jan 31 2008, 10:59 PM
KaptKaos   Was it another holiday today...? :confused: :c...   Jan 31 2008, 11:22 PM
KaptKaos   So today, I got some FI fuel line, and rigged it u...   Feb 2 2008, 05:12 PM
KaptKaos   :barf: Checked PP. The first thing is a fuel ac...   Feb 2 2008, 05:19 PM
KaptKaos   I put a new fuel filter on it today, and I "t...   Feb 16 2008, 06:40 PM
racerx9146   try pull the intake boot off the cis fuel distribu...   Feb 16 2008, 08:23 PM
KaptKaos   I was following Slits' CIS issues. IIRC - h...   Mar 29 2008, 09:52 PM
SLITS   Joe, the center piston is what HAS TO BE FREE. It...   Mar 30 2008, 08:11 AM
Gint   PS Gint ... I started to write this up for your si...   Mar 30 2008, 01:25 PM
SLITS   [quote name='SLITS' post='1014594' date='Mar 30 2...   Mar 31 2008, 12:44 PM
KaptKaos   :trophy: :trophy: :trophy: :trophy: :trophy: ...   Mar 30 2008, 09:45 AM
euro911   ... Danka Herr Doktor! I'd love to come o...   Mar 30 2008, 02:25 PM
KaptKaos   :rotfl: We really should build one of these. E...   Mar 30 2008, 02:50 PM
Eric_Shea   It's "Professor" H-E-L-L-O! ...   Mar 30 2008, 06:19 PM
Dr Evil   :popcorn: Mmm, Vicodin   Apr 1 2008, 02:43 AM
KaptKaos   IT IS ALIVE! :trophy: :trophy: But..........   May 4 2008, 06:24 PM
SLITS   [size=7][color=#FF0000]IT IS ALIVE! :trophy...   May 4 2008, 11:23 PM
shoguneagle   Great job and excellent support as always from fol...   Aug 17 2009, 09:03 PM
- Lo-Fi Version Time is now: 30th September 2026 - 11:03 PM
