| carr914 |
May 23 2013, 09:41 AM
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 131,990 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
IF anyone decides to produce more emblems I would like a: 914-6-2.2 You guys are making this too hard on your selves! Anybody can do this at home - take Two 914 Emblems, cut the 9 off one of them turn it upside down, get out at Soldering Iron and Bam you're done! For the 2.2, do the same thing, take two 2.0 emblems, cut the Zeros off & Solder the 2's together Of course you could also go to a Sign shop & have them make these in Vinyl! ![]() |
| RJMII |
May 23 2013, 10:12 AM
Jim McIntosh ![]() ![]() ![]() ![]() Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
I can do them in vinyl. :-) I have pink loaded up right now in the vinyl cutter; who's first?
my router table is set up for wood... IF I were to start making them again, I'd have to build another cnc mini mill. With the amount of PM's showing support, it is tempting. Thank you ALL for the PM's, kind words, and notes of encouragement! |
| Chris H. |
May 23 2013, 10:18 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,079 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest
| billh1963 |
May 23 2013, 11:42 AM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,431 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
IF anyone decides to produce more emblems I would like a: 914-6-2.2 You guys are making this too hard on your selves! Anybody can do this at home - take Two 914 Emblems, cut the 9 off one of them turn it upside down, get out at Soldering Iron and Bam you're done! For the 2.2, do the same thing, take two 2.0 emblems, cut the Zeros off & Solder the 2's together Of course you could also go to a Sign shop & have them make these in Vinyl! ![]() Don't throw logic into this discussion! (IMG:style_emoticons/default/happy11.gif) |
| MoveQik |
May 23 2013, 12:27 PM
What size wheels can I fit? ![]() ![]() ![]() ![]() Group: Members Posts: 4,667 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
You guys are making this too hard on your selves! Anybody can do this at home - take Two 914 Emblems, cut the 9 off one of them turn it upside down, get out at Soldering Iron and Bam you're done! Great idea!! Ok, so I need someone to make me two 914 emblems (IMG:style_emoticons/default/laugh.gif) |
| Mark Henry |
May 23 2013, 04:19 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
IF anyone decides to produce more emblems I would like a: 914-6-2.2 You guys are making this too hard on your selves! Anybody can do this at home - take Two 914 Emblems, cut the 9 off one of them turn it upside down, get out at Soldering Iron and Bam you're done! For the 2.2, do the same thing, take two 2.0 emblems, cut the Zeros off & Solder the 2's together Of course you could also go to a Sign shop & have them make these in Vinyl! ![]() But how do I do 3.0? (IMG:style_emoticons/default/idea.gif) |
| timothy_nd28 |
May 23 2013, 04:30 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest
Carefully file away this part
![]() For the "0" you'll need a sharpie marker |
| Eric_Shea |
May 23 2013, 04:43 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
You guys are making this too hard on your selves! Anybody can do this at home - take Two 914 Emblems, cut the 9 off one of them turn it upside down, get out at Soldering Iron and Bam you're done! Great idea!! Ok, so I need someone to make me two 914 emblems (IMG:style_emoticons/default/laugh.gif) Not a problem. you should be able to make two emblems out of four emblems. (you're welcome) |
| Mr.242 |
May 23 2013, 10:52 PM
May your glass be smaller so it's always FULL! ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 10-June 08 From: Seattle Member No.: 9,160 Region Association: Pacific Northwest |
So Glad to hear Jim is working on leveling this all out. I'm always happy to hear of people overcoming adversity!
I hope someone else works on getting emblems made or available on a consistent basis. (IMG:style_emoticons/default/poke.gif) |
| Mark Henry |
May 24 2013, 07:35 AM
Just thinking..... (IMG:style_emoticons/default/idea.gif) couldn't I make a simple mold out plasticine then fill it with JB weld? I could even stick mounting pins in it.
Give it coat of paint when it's done. |
| sixnotfour |
May 24 2013, 08:12 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,184 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
| aircooledtechguy |
May 25 2013, 12:14 AM
The Aircooledtech Guy ![]() ![]() ![]() Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
I never got mine and it's not in the photo of the ones that Tim made. Obviously Jim needed my $115 or so more than I did. At this point, I don't even want the emblem. I'll have mine and all future emblems made locally. Its nice to patronize guys/gals on this forum that I know I can trust. For all other needs, I'll just go where I can look the person in the eye, shake their hand, or if need be, grab them by the collar.
Stress, in this case, has been created by those who have it, by their own hands. Tim; My hat is off to you for your selfless efforts. That's one hell of a gesture. "Blessed is the peace maker." (IMG:style_emoticons/default/beerchug.gif) |
| RJMII |
May 25 2013, 07:25 AM
I never got mine and it's not in the photo of the ones that Tim made. Obviously Jim needed my $115 or so more than I did. At this point, I don't even want the emblem. I'll have mine and all future emblems made locally. Its nice to patronize guys/gals on this forum that I know I can trust. For all other needs, I'll just go where I can look the person in the eye, shake their hand, or if need be, grab them by the collar. Stress, in this case, has been created by those who have it, by their own hands. Tim; My hat is off to you for your selfless efforts. That's one hell of a gesture. "Blessed is the peace maker." (IMG:style_emoticons/default/beerchug.gif) Laser cutter because of the Q. Not going to see it in mill pile. ;-) |
| mepstein |
May 25 2013, 07:31 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
my router table is set up for wood... IF I were to start making them again, I'd have to build another cnc mini mill. With the amount of PM's showing support, it is tempting. (IMG:style_emoticons/default/blink.gif) |
| RJMII |
May 25 2013, 08:13 AM
my router table is set up for wood... IF I were to start making them again, I'd have to build another cnc mini mill. (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/beerchug.gif) sarcasm, strike the cage. (IMG:style_emoticons/default/wink.gif) |
| 914six |
May 25 2013, 03:08 PM
Newbie ![]() Group: Members Posts: 28 Joined: 29-March 10 From: Los Angeles, CA Member No.: 11,521 Region Association: Southern California |
Guys,
Got my emblem in the mail today... Thanks to Tim & Jim.... |
| gothspeed |
May 25 2013, 05:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Not to butt in or hi-jack ........ but after all is said and done, if there happens to be an extra 914-GT emblem, I will take it ..... (IMG:style_emoticons/default/popcorn[1].gif)
| timothy_nd28 |
May 25 2013, 08:57 PM
Guys, Got my emblem in the mail today... Thanks to Tim & Jim.... (IMG:style_emoticons/default/aktion035.gif) |
| Mike Bellis |
May 25 2013, 09:58 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
I got mine too. Looks great!!!
| Tom_T |
May 27 2013, 09:59 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
Lo-Fi Version | Time is now: 2nd April 2026 - 08:55 AM |
