third brake light wiring |
keely444 |
Jun 26 2016, 03:57 PM
Member Group: Members Posts: 103 Joined: 4-May 15 From: santa cruz Member No.: 18,702 Region Association: None |
I want to see if I could tap into a Black / Yellow brake light wire around the pedal area inside the car. I am using a led stripe for the third light and I want to keep everything in the inside of the car. I don't have any wiring diagrams so I was looking for some help. I aleady tested it all out back at the tail light terminal and it all works fine back there. I tried a tap and the light is constant on and no affect when I push the brake pedal. Not to protectant in the electrical areas.
Creamsicle New Zealand |
Jun 26 2016, 04:59 PM
Member Group: Members Posts: 83 Joined: 5-February 15 From: New Zealand Member No.: 18,403 Region Association: Australia and New Zealand |
I need to run a third break light for my compliance, was looking at running the wire from one of the rear tail light units as there are push on electrical fittings so just need the add a piggy back fitting which will easy then run the wiring as discreetly as possible with the existing wiring loom to the third light, I'm looking at interior third light so will be able to run the wires behind rear panel (behind seats). I would rather not have to do it but our laws state I must.
Let me know what you end up doing. Steve |
Jun 26 2016, 05:03 PM
I want to see if I could tap into a Black / Yellow brake light wire around the pedal area inside the car. I am using a led stripe for the third light and I want to keep everything in the inside of the car. I don't have any wiring diagrams so I was looking for some help. I aleady tested it all out back at the tail light terminal and it all works fine back there. I tried a tap and the light is constant on and no affect when I push the brake pedal. Not to protectant in the electrical areas. You could be hooking into the wrong side of the switch? |
era vulgaris |
Jun 26 2016, 05:08 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
You could be hooking into the wrong side of the switch? (IMG:style_emoticons/default/agree.gif) Looking at this diagram for a '73 (not sure what year yours is), there is a black/yellow wire coming from the fuse panel to the switch, and then another black/yellow wire from the switch to the brake lights. You probably tapped into the one coming from the fuse panel. Try the other one. (35 is the brake light switch, and 14 are the brake lights.) http://www.pelicanparts.com/914/parts/Elec...lectric_73A.jpg http://www.pelicanparts.com/914/parts/Elec...lectric_73B.jpg Also here are some more schematics for different years: http://www.pelicanparts.com/914/914_electrical_diagrams.htm |
Amphicar770 |
Jun 26 2016, 05:17 PM
Senior Member Group: Members Posts: 1,195 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
I tapped my 3rd brake light into the wiring that goes into the brake light itself at rear of car. Simple and effective. The LED draws very little power.
keely444 |
Jun 26 2016, 05:24 PM
I want to see if I could tap into a Black / Yellow brake light wire around the pedal area inside the car. I am using a led stripe for the third light and I want to keep everything in the inside of the car. I don't have any wiring diagrams so I was looking for some help. I aleady tested it all out back at the tail light terminal and it all works fine back there. I tried a tap and the light is constant on and no affect when I push the brake pedal. Not to protectant in the electrical areas. You could be hooking into the wrong side of the switch? That was it. I will post pics once I put it all together.I did some more reading and my brain clicked on. |
toolguy |
Jun 26 2016, 05:43 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Intercept the wire from the brake switch in the harness between the seats under the center tray.
bandjoey |
Jun 26 2016, 08:31 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Pigtail onto a brake light and run the wires up the harness to the rolbar or wherever the light is. 15 minutes and you're in business.
dangrouche |
Jun 26 2016, 09:07 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
here is my instrux for giving juice to your 3rd brake lite from the rear lamp housing; look at the second picture
http://www.914world.com/bbs2/index.php?showtopic=212499 |
keely444 |
Jun 26 2016, 09:16 PM
Got most of it done. I did this on my other car and really like it.With every other driver playing on their phone and SUV 's that cant see you it gives you a fighting chance not to get your classic rear ended.I also like how discrete it is when its not lit up.Most people would never notice its on your Porsche.
Lo-Fi Version | Time is now: 3rd June 2024 - 07:35 AM |
