| zach914v8 |
Aug 22 2016, 10:24 PM
Member ![]() ![]() Group: Members Posts: 216 Joined: 26-November 10 From: Houston Member No.: 12,426 Region Association: Southwest Region |
My chassis wire harness is garbage. Recently the wires have started to disintegrate and I have shorts everywhere. When I fix one spot somewhere else fails, and I have to band-aid more crap. I am starting to worry about my car catching fire, and I'm tired of it.
My car is a 74 with a carbed v8. I'm not thrilled about the prospect of buying a used 40yo harness either. My question is have any of you out there installed a painless/universal chassis harness in your cars? If so how did you wire the dimmer/light switch/pop up headlights and 2 speed wipers? What problems did you come across, and what fix it? Thanks Zach |
| whitetwinturbo |
Aug 22 2016, 10:37 PM
Honey, does this wing make my ass look fat? ![]() ![]() ![]() Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
Hi Zach,
What is causing the brittle conditions? Car outside? Love to see a picture of your sled (IMG:style_emoticons/default/beer.gif) |
| Chris914n6 |
Aug 22 2016, 11:44 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,528 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
There is a guy on ebay that has a good portion of the factory stripes on hand. I would, and will need to myself someday, rebuild the factory harness per spec and add in a few for the Nissan engine and gauges, power windows & locks, extra lights and stuff.
I've already added relays for the headlights and starter to get the current out of the switches. I also bought a couple of blade fuse boxes to update that and will run the rear wires thru the driver long instead of over to the middle of the car and back in front of the engine. |
| zach914v8 |
Aug 23 2016, 06:11 AM
I have owned the car for 17 years. I bought it when I was 18, so it has had to be parked outside for various reasons over the years. Now that Im old and own a house it lives in a proper garage.
I really want to put in something new as far as the wiring is concerened. The car is for the most part a race car, I only want the bar bones functions. Lights, turn signals, brake lights, wipers, gauges, engine, ect.. Im sure someone out there has put a universal wire harness in one of these cars. I wired a 36 ford at work with a painless kit and it was easy. But the kit was set up for a gm ignition switch, single speed wipers and a gm headlight switch, no pop up lights. So some problems will arise with universal harness, but I think they can be worked around. These cars are old, and getting older and the options are thin. |
| JeffBowlsby |
Aug 23 2016, 10:09 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,222 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
A universal harness has no chance of working. The factory harness has around 170 circuits. Your best bet at this juncture would be to have a new custom harness built. There is that guy in the Netherands that may have them available. About $3K.
| 2mAn |
Aug 23 2016, 10:27 AM
trying to see how long I can go without a 914 ![]() ![]() Group: Members Posts: 499 Joined: 14-November 13 From: Westchester (Los Angeles) Member No.: 16,644 Region Association: Southern California |
I second Jeffs recommendation, but if the only two issues you can currently think of are the pop up lights and the wipers, I think the GT headlight setup is a manual lift, and that narrows your potential problem down to just wipers.
| zach914v8 |
Aug 23 2016, 11:23 AM
I have seen pictures of the GT manual headlights, super cool. I would love to do that.
Jeff, just curious what about a universal harness wont work? I can install a gm ignition switch in the dash, or just a push start button. All the seat belt warnings and interior lams and all that minor garbage I don't want. so really all I need is... Lights Starter Ignition Wiper Hazards Brake Turn signal Fuel pump Gauges Alternator Why is this impossible? |
| JeffBowlsby |
Aug 23 2016, 11:36 AM
Its pretty simple. Study the factory wiring schematics then compare them to the universal kits. Its apples and oranges, nothing fits and the universal kits are not complete.
Then think about how to connect things - are you using the original factory switches, relay board? You already mentioned using a GM ignition switch. Ugh. Anything can be forced fit to make it work out of necessity, but there will be sacrifices - in quality, reliability and performance. Once you put in something like that is an obvious kluge job, think for one second about what that does to your resale value and who can maintain it. |
| zach914v8 |
Aug 23 2016, 11:54 AM
Resale is of no concern whatsoever to me, and I do all my own work so got that covered.
Thousands of people, myself included have used a painless wiring kit. I would hardly call that set up a "kluge" job as you called it. Lot of very beautiful installs with that kit in hot rods all over the world. I probably wouldn't use a single factory switch if I didn't have to. I like the idea of being able to go to any parts store in america and buy the parts I need for my car. |
| jd74914 |
Aug 23 2016, 12:14 PM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,875 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I don't see any problem with using a universal harness kit. Most people seem to be against them because of the hack installs; there are tons of excellent installs as you noted. (IMG:style_emoticons/default/smile.gif)
The biggest thing is getting a timer relay to move the headlight motors which shouldn't be too hard (caveat: I've never looked for an automotive one but industrial ones are pretty easy to find). I'm planning on rewiring my car using an InfinityWire kit because I got a great deal on a used one. It'll be a little easier since the headlight motor timing can just be added to the control logic. http://infinitybox.com/ |
| zach914v8 |
Aug 23 2016, 01:10 PM
I don't see any problem with using a universal harness kit. Most people seem to be against them because of the hack installs; there are tons of excellent installs as you noted. (IMG:style_emoticons/default/smile.gif) The biggest thing is getting a timer relay to move the headlight motors which shouldn't be too hard (caveat: I've never looked for an automotive one but industrial ones are pretty easy to find). I'm planning on rewiring my car using an InfinityWire kit because I got a great deal on a used one. It'll be a little easier since the headlight motor timing can just be added to the control logic. http://infinitybox.com/ Wow, why have I never seen this infinity box before? This looks awesome. Guess I have some reading to do. That sound like it could be a slic option. I am not trying to upset anyone here on the board. Its funny because I think that most v8 914 guys are hot rodders, and most of the air cooled guys are porsche people. Sometimes we get our wires crossed(no pun intended...lol). At our car loving cores we are fundamentally different folks. I would prefer if evey part in my porsche was replaced with a/c delco, motorcraft, or mopar . I understant that that the thought of those parts in a 914 would make many here very queezy.... lol and thats fine just understand that we are different and have different goals. |
| Downunderman |
Aug 23 2016, 01:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
My sentiment entirely. For the car I'm building at the moment I'm going to use one of these http://bluewireautomotive.com/products/20-...es-wire-harness as the existing loom is a shambles. Headlights will have a GT kit.
| JeffBowlsby |
Aug 23 2016, 01:34 PM
Agreed. And appreciate the recognition of different perspectives.
The 914 can be a hot rodders car...so more power to ya... Be sure to post details and photos of how it all works out for you. |
| mb911 |
Aug 23 2016, 02:20 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,729 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Sounds like what we need to do is just make a new harness coping the old one.. Just need to source the connectors and should be straight forward. I would have consider making a few of them.
| SirAndy |
Aug 23 2016, 02:30 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I bought a complete and unmolested chassis harness from a dismantler for $150 ...
(IMG:style_emoticons/default/shades.gif) |
| Chris914n6 |
Aug 23 2016, 03:24 PM
Why the all or nothing approach? Keep or restore the headlight wires, the motors run off 1 fuse. The column plugs will be tricky but just about everything else is 1/4" connector.
Does Painless include engine to gauges wiring? |
| SixerJ |
Aug 23 2016, 03:31 PM
Member ![]() ![]() Group: Members Posts: 451 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
A universal harness has no chance of working. The factory harness has around 170 circuits. Your best bet at this juncture would be to have a new custom harness built. There is that guy in the Netherands that may have them available. About $3K. Jeff, your talking about this guy right? Deep pocket stuff, but lovely none the less http://www.kroonwireharnesses.com With the universal harness, if it means that the OP has a grin on his face while (IMG:style_emoticons/default/driving.gif) and not worried about Whispy white smoke making an appearance, then why not |
| Mike Bellis |
Aug 23 2016, 04:05 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
It can be done. Not easy but can be done. The biggest challenge are the turn signals and brake lights. The 914 separates these into their own circuits and the universal kits have a turn/brake light common circuit. The control for which is part of the turn signal stalk. They actually run the brake light circuit into the stalk to cut off from the turn when the stalk is rotated.
I would need to study the 914 stalk diagram to determine if it could be used or modified to work. It might be easier to keep the 914 turn signal circuit in place and graft it into the universal kit. Anything can be done with enough knowledge... |
| matthepcat |
Aug 23 2016, 04:27 PM
Meat Popsicle ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
I believe member fasthonda put in an 8 circuit universal wiring harness in his S2000 swapped car:
http://www.914world.com/bbs2/index.php?showtopic=97897 The car is actually still for sale here: http://fasthonda.blogspot.com/2015/12/fasthonda-garage.html |
| Cory M |
Aug 23 2016, 05:26 PM
Newbie ![]() Group: Members Posts: 19 Joined: 31-March 06 From: san diego Member No.: 5,798 |
Not much info on this in the Porsche world. All Porsche technicians will recommend a used factory harness. But if you do a search of Samba you can see several examples of people installing various universal kits for bugs and buses from places like American Autowire, Ron Francis, and Rebel Wiring. If you don't need to keep your factory switches it makes things a lot easier. Good luck whatever you decide.
Lo-Fi Version | Time is now: 2nd April 2026 - 08:55 AM |
